Hi Blade,
Just trying a few thing in HS3 to see if all my need are meet before moving over and one of the things I needed is to be able to use a USBUirt so firstly thanks for creating this plugin
Ok here is my little contribution, Its a little program that I found ages ago to help with the learning of IR codes, It also allows you to paste IR codes into a window and inject into the IR learner window, thats if like me you tuck the precaution of saving a copy of all the IR codes that you scanned or find a remote data base like http://www.remotecentral.com/
Just tried it works a treat, just run from the folder at the same time as you are learning your codes into the USBUirt.
