I had an issue with directories and files slowly disappearing. Icons that used to be there no longer existed. Then more and more warnings. I couldn't even find anything with WinSCP.
So I decided to reinstall the OS (if that's the right terminology). I plugged a kb/mouse and monitor into the Zee and reinstalled. However, I can't find the Zee on the network. The router info shows "recovery" instead of the Hometroller verbiage you usually see and I can't see the system using find.homeseer.com.
I also have a Network Watcher Utility and the Hometroller doesn't show up on there either. I even tried typing "r <enter> in the linux startup screen to try and reset the network settings to no avail.
I can log in to linux by typing homeseer and hsthsths3 but then I have no clue what I could do other than make matters worse.
Help please!
Help please!
