Hi Blade - trying to see if I can get My CAV66 (connected to a Global Cache serial port - but also has RNET enabled) to be recognized by your plugin. Can you give me the basics of what I need. I have a GCC plugin in HS3 but I can't seem to make the connections for COM ports on the GCC
CAV 66 and Global Cache
You might want to check out this similar thread that just transpired: https://forums.homeseer.com/showthread.php?t=192343Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
