Go Back   HomeSeer Message Board > Analog & Digital IO Device Plug-ins > Analog & Digital IO Discussion > Arduino Plugin (3P)
Arduino Plugin (3P) Discussions related to the Arduion plugin for HS3 by enigmatheatre
Old July 14th, 2017, 11:58 PM
Conrad_Turbo Conrad_Turbo is online now
Seer Deluxe
Custom API help? - Adding a pushbutton
I'm starting off basic...I want to have a pushbutton toggle an output off and on, then i'll be elborating with more pushbuttons and outputs, then link it to HS. This is what I have so far:
 *Arduino to Homeseer 3 Plugin API written by Enigma Theatre.*
 * V1.0.0.140                                                *
int FromHS[50];
boolean IsConnected = false;
//**************Declare your variables here*******************
//Inputs
int FogPin = 10;
//Outputs
int DrivFogLight = 16;
int PassFogLight = 5;
//Variables
int stateFog = HIGH;
int readingFog;
int previousFog = LOW;
long time = 0;
long debounce = 200;
void HSSetup() {
  //Add YOUR SETUP HERE;
//Define Input Pins
  pinMode(FogPin, INPUT);
//Define Output Pins
  pinMode(DrivFogLight, OUTPUT);
  pinMode(PassFogLight, OUTPUT);
void HSloop() {
    //Add YOUR CODE HERE;
    /* To Send Data to Homeseer use SendToHS(Device,Value)
     Eg.. SendToHS(1,200); where 1 is the API device in homeseer and 200 is the value to send
     To Recieve data from Homeseer look up the FromHS array that is updated when the device value changes.
     Eg.. FromHS[5] would be the data from API Output device 5
     All code that is located just below this block will execute regardless of connection status!
     You can include SendToHS() calls, however when there isn't an active connection, it will just return and continue.
     If you only want code to execute when HomeSeer is connected, put it inside the if statement below.
    /*Execute regardless of connection status*/
//Monitoring the Fog Light Pin
readingFog = digitalRead(FogPin);
// if we just pressed the button (i.e. the input went from LOW to HIGH),
// and we've waited long enough since the last press to ignore any noise...
if (readingFog == HIGH && previousFog == LOW && millis() - time > debounce) {
  // ... invert the output
  if (stateFog == HIGH)
    stateFog = LOW;
  else
    stateFog = HIGH;
    // ... and remember when the last button press was
   time = millis();
digitalWrite(DrivFogLight, stateFog);
digitalWrite(PassFogLight, stateFog);
previousFog = readingFog;
 if (IsConnected == true) {
   /*Execute ONLY when HomeSeer is connected*/
//************Do not change anything after Here*****************
Now I can get this code to run just fine on it's on, but when I put it into the HS API I get a compiling error due to the use of "time". Any idea as the time is used for debounce with this switch but also must be used in the HS section too.
Quote:
C:\Users\conradan\AppData\Local\Temp\arduino_build_565717/arduino.ar(time.c.o): In function `time':
C:\Users\conradan\AppData\Local\Arduino15\packages\esp8266\h ardware\esp8266\2.3.0-rc2\cores\esp8266/time.c:93: multiple definition of `time'
C:\Users\conradan\AppData\Local\Temp\arduino_build_565717\sk etch\APIBoard3.ino.cpp.o.bss.time+0x0): first defined here
c:/users/conradan/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: Warning: size of symbol `time' changed from 4 in C:\Users\conradan\AppData\Local\Temp\arduino_build_565717\sk etch\APIBoard3.ino.cpp.o to 29 in C:\Users\conradan\AppData\Local\Temp\arduino_build_565717/arduino.ar(time.c.o)
c:/users/conradan/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9-2/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: Warning: type of symbol `time' changed from 1 to 2 in C:\Users\conradan\AppData\Local\Temp\arduino_build_565717/arduino.ar(time.c.o)
collect2.exe: error: ld returned 1 exit status
Old July 15th, 2017, 12:51 AM
logbuilder logbuilder is online now
Seer Master
Name your variable something other than time. Maybe PreviousMillis.
Also, and this may just be me being anal, I would change your if statement to be more clear of your intentions.
Now
My change
if ((readingFog == HIGH) && (previousFog == LOW) && ((millis() - PreviousMillis) > debounce)) {
Old July 16th, 2017, 12:46 AM
Seer Master
Are you still stuck or are you ok?
Old July 17th, 2017, 12:17 PM
Seer Deluxe
I was away all weekend, but I was working on this offline and found some other sample code. So stripped everything down and have one MO pushbutton and a relay connected to an output. I can get it to work with this code, no problem.
 Debounce
 Each time the input pin goes from LOW to HIGH (e.g. because of a push-button
 press), the output pin is toggled from LOW to HIGH or HIGH to LOW.  There's
 a minimum delay between toggles to debounce the circuit (i.e. to ignore
 noise).
 The circuit:
 * LED attached from pin 13 to ground
 * pushbutton attached from pin 2 to +5V
 * 10K resistor attached from pin 2 to ground
 * Note: On most Arduino boards, there is already an LED on the board
 connected to pin 13, so you don't need any extra components for this example.
 created 21 November 2006
 by David A. Mellis
 modified 30 Aug 2011
 by Limor Fried
 modified 28 Dec 2012
 by Mike Walters
 modified 30 Aug 2016
 by Arturo Guadalupi
 This example code is in the public domain.
 http://www.arduino.cc/en/Tutorial/Debounce
// constants won't change. They're used here to
// set pin numbers:
const int FogButtonPin = 10;    // the number of the pushbutton pin
const int DrivFogLightPin = 16;      // the number of the LED pin
// Variables will change:
int FogState = HIGH;         // the current state of the output pin
int readingFog;             // the current reading from the input pin
int lastreadingFog = LOW;   // the previous reading from the input pin
// the following variables are unsigned long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
unsigned long lastDebounceTime = 0;  // the last time the output pin was toggled
unsigned long debounceDelay = 50;    // the debounce time; increase if the output flickers
void setup() {
  pinMode(FogButtonPin, INPUT);
  pinMode(DrivFogLightPin, OUTPUT);
  // set initial LED state
  digitalWrite(DrivFogLightPin, FogState);
void loop() {
  // read the state of the switch into a local variable:
  int reading = digitalRead(FogButtonPin);
  // check to see if you just pressed the button
  // (i.e. the input went from LOW to HIGH),  and you've waited
  // long enough since the last press to ignore any noise:
  // If the switch changed, due to noise or pressing:
  if (reading != lastreadingFog) {
    // reset the debouncing timer
    lastDebounceTime = millis();
  if ((millis() - lastDebounceTime) > debounceDelay) {
    // whatever the reading is at, it's been there for longer
    // than the debounce delay, so take it as the actual current state:
    // if the button state has changed:
    if (reading != readingFog) {
      readingFog = reading;
      // only toggle the LED if the new button state is HIGH
      if (readingFog == HIGH) {
        FogState = !FogState;
  // set the LED:
  // save the reading.  Next time through the loop,
  // it'll be the lastreadingFog:
  lastreadingFog = reading;
It works great. Toggles the relay on and off. No probs. Now I snip and move those pieces into the HS API and nothing happens.
 * V1.0.0.140                                                *
int FromHS[50];
//Inputs
//Outputs
//Variables
void HSSetup() {
//Define Input Pins
//Set Initial Light State
void HSloop() {
  // set the LED:
I also tried your suggestion on changing the variable and it didn't work either...not sure what's up...I feel like this is a small hurdle and once I'm over it, it should open up a lot of options.
Old July 17th, 2017, 03:38 PM
enigmatheatre's Avatar
enigmatheatre enigmatheatre is offline
Super Seer
Can you post the full API sketch file you are uploading to the board.
Greig.
Zwave = Z-Stick, 3xHSM100™ 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts =
Various
Old July 17th, 2017, 04:18 PM
Seer Master
During initial development, I will often insert Serial.println("Testing debug line") statements to let me see the logic path as well as examine contents of variables. Then on the IDE you can use the serial monitor to see the debug lines. Once the code is operating properly, I will either comment the lines or remove them.
Old July 17th, 2017, 04:27 PM
Seer Master
For what it is worth, here is code that I use in one of my configurations that has 6 buttons on it. They are momentary buttons. It doesn't include any debounce logic but it does work.
// Button Variables
int ButtonCnt = 6;        // can support from 0 to 6 buttons. Set this to the # you have
int ButtonIndex = 0;
int ButtonPin[]= {4, 2, 12, 13, 16, 5};
int ButtonDevice[]= {7, 8, 9, 10, 11, 12};
int ButtonStatus[] = {HIGH, HIGH, HIGH, HIGH, HIGH, HIGH};
int ButtonReadStatus = HIGH;
void HSSetup() {
  for (ButtonIndex  = 0; ButtonIndex < ButtonCnt; ButtonIndex++) {
     if (ButtonPin[ButtonIndex]) pinMode(ButtonPin[ButtonIndex],  INPUT_PULLUP);
void HSloop() {
// ************  Start of 'Buttons' *************
// ***** Up to six buttons may be processed *****
   if (ButtonIndex) {
        if (ButtonPin[ButtonIndex]) {
           ButtonReadStatus = digitalRead(ButtonPin[ButtonIndex]);
           if (ButtonReadStatus != ButtonStatus[ButtonIndex]) {
              if (ButtonReadStatus == LOW) SendToHS(ButtonDevice[ButtonIndex],100);
              if (ButtonReadStatus == HIGH) SendToHS(ButtonDevice[ButtonIndex],0);
              ButtonStatus[ButtonIndex] = ButtonReadStatus;
// ****** End of 'Buttons' **************
Old July 17th, 2017, 05:04 PM
Seer Deluxe
This is the whole code. Doesn't throw any compile errors when uploading to the board. I am running this outside of my home wifi network so I can't see it connect or anything yet...just trying to get the pushbutton stuff to work and then I can get within my wifi network.
I'll try the serial print to see where things go awry. Or I'll try and use your code and see what's up too. I know it has to be something simple I'm missing.
I omitted the rest of the code before as it had IP, wifi, password etc...but I just changed them to random stuff for stray prying eyes.
 * V1.0.0.140                                                *
int FromHS[50];
//Inputs
//Outputs
//Variables
void HSSetup() {
//Define Input Pins
void HSloop() {
  // set the LED:
#define ISIP 1
#define BoardType 3
const byte BoardAdd = 3;
#include <EEPROM.h>
#if BoardType == 3
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
char ssid[] = "The Internet";
char pass[] = "123456";
#else
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#endif
#if ISIP == 1
byte mac[] = {0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x03};
IPAddress ip(192,168,1,140);     //IP entered In HS config.
const unsigned int localPort = 8910;      //port entered In HS config.
IPAddress HomeseerIP(192,168,1,190); //Homeseer IP address
IPAddress ServerIP(EEPROM.read(2),EEPROM.read(3),EEPROM.read(4),EEPROM.read(5));
IPAddress gateway(192,168,1,1);
IPAddress subnet(255,255,255,0);
byte EEpromVersion = EEPROM.read(250);
char packetBuffer[UDP_TX_PACKET_MAX_SIZE];
const unsigned int ServerPort = 8888;
#endif
#if BoardType == 3
WiFiUDP Udp;
WiFiUDP SendPort;
#else
EthernetUDP Udp;
#endif
#if BoardType == 3
void resetFunc() {
  ESP.restart();
#else
void(* resetFunc) (void) = 0;
#endif
char* Version = "API1.0.0.140";
byte Byte1, Byte2, Byte3;
unsigned int Byte4, Byte5;
void setup() {
#if BoardType == 3
 // WiFi.persistent(false);
  EEPROM.begin(256);
#endif
#if ISIP == 1
    if (EEpromVersion!=22) {
    ServerIP=HomeseerIP;
    EEPROM.write(2,ServerIP[0]);
    EEPROM.write(3,ServerIP[1]);
    EEPROM.write(4,ServerIP[2]);
    EEPROM.write(5,ServerIP[3]);
    EEPROM.write(250,22); //Store the version where the eeprom data layout was last changed
    EEpromVersion=22;
#if BoardType == 3
  //Serial.begin(115200);
  WiFi.begin(ssid, pass);
  WiFi.config(ip, gateway, subnet);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
#else
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
#endif
  Udp.begin(localPort);
  Udp.setTimeout(0);
  delay(1000);
SendConnect();
#else
  Serial.flush();
  Serial.setTimeout(0);
  delay(1000);
  Serial.print("Connect ");
  Serial.println(BoardAdd);
#endif
HSSetup();
void loop(){
  HSloop();
#if ISIP == 1
  UDPCheck();
#endif
void SendConnect()
#if ISIP == 0
#else
    Udp.beginPacket(HomeseerIP,ServerPort);  //First send a connect packet to the dynamic IP stored in eeprom
    Udp.print("Connect ");
    Udp.print(BoardAdd);
    Udp.endPacket();
    if (ServerIP!=HomeseerIP) {
      Udp.beginPacket(HomeseerIP,ServerPort);  //Then if the stored value doesn't match the pre-specified one, send a connect packet there also
      Udp.endPacket();
#endif
#if ISIP == 1
void UDPCheck(){
  int packetSize = Udp.parsePacket();
  if(packetSize)
 #if BoardType == 3
    IPAddress remote = Udp.remoteIP();
    Byte1 = Udp.parseInt();
    Udp.read();
    Byte2 = Udp.read();
    Udp.read();
    Byte3 = Udp.parseInt();
    Udp.read();
    Byte4 = Udp.parseInt();
    Udp.read();
    Byte5 = Udp.parseInt();
    DataEvent();
    #else
   ServerIP = Udp.remoteIP();
    Udp.read();
    Byte2 = Udp.read();
    Byte3 = Udp.parseInt();;
    Byte5 = Udp.parseInt();;
    DataEvent();
#endif
#else
void serialEvent() {
  while (Serial.available() > 0) {
    delay(17);
    Byte1 = Serial.parseInt();
    Serial.read();
    Byte2 = Serial.read();
    Byte3 = Serial.parseInt();
    Byte4 = Serial.parseInt();
    Byte5 = Serial.parseInt();
    DataEvent();
#endif
Used Data Input Cases
D Disconnect
r reset
K Keepalive
O PinMode Output Set
d Input debounce time set
C Connect request
c Connection established - report current status
void DataEvent() {
  if (Byte1 == BoardAdd) {
#if ISIP == 1
      if (Udp.remoteIP() != ServerIP) {
        ServerIP=Udp.remoteIP();
#endif
    switch (Byte2) {
    case 'c':
      IsConnected = true;
      break;
    case 'C':
#if ISIP == 1
      Udp.beginPacket(HomeseerIP, ServerPort);
      Udp.print("Version ");
      Udp.print(" ");
      Udp.print(Version);
      Udp.println(" HS3");
      Udp.endPacket();
      delay(100);
      Udp.print("Connected ");
      Udp.println(BoardAdd);
      Udp.endPacket();
#else
      Serial.print("Version ");
      Serial.print(BoardAdd);
      Serial.print(" ");
      Serial.print(Version);
      Serial.println(" HS3");
      delay(100);
      Serial.print("Connected ");
#endif
      delay(100);
      break;
    case 'K':
      delay(200);
#if ISIP == 1
      Udp.print("Alive ");
      Udp.endPacket();
#else
      Serial.print("Alive ");
#endif
      break;
      case 'r':
      delay(200);
      resetFunc();  //call reset
      break;
    case 'O':
      FromHS[Byte3] = Byte4;
      break;
    case 'D':
      break;
void SendToHS(byte Device, long Data){
#if ISIP == 1
  Udp.print(" API ");
  Udp.print(Device);
  Udp.print(" ");
  Udp.print(Data);
  Udp.endPacket();
#else
  Serial.print(" API ");
  Serial.print(Device);
  Serial.print(" ");
  Serial.println(Data);
#endif
void SendToHS(byte Device, int Data){
#if ISIP == 1
  Udp.print(" API ");
  Udp.print(Device);
  Udp.print(" ");
  Udp.print(Data);
  Udp.endPacket();
#else
  Serial.print(" ");
#endif
void SendToHS(byte Device, float Data){
#if ISIP == 1
  Udp.print(" API ");
  Udp.print(Device);
  Udp.print(" ");
  Udp.print(Data);
  Udp.endPacket();
#else
  Serial.print(" ");
#endif
void SendToHS(byte Device, double Data){
#if ISIP == 1
  Udp.print(" API ");
  Udp.print(Device);
  Udp.print(" ");
  Udp.print(Data);
  Udp.endPacket();
#else
  Serial.print(" ");
#endif
Old July 17th, 2017, 05:55 PM
Super Seer
 * V1.0.0.140                                                *
int FromHS[50];
//Inputs
//Outputs
//Variables
void HSSetup() {
//Define Input Pins
void HSloop() {
  // set the LED:
#define ISIP 1
#define BoardType 3
#include <EEPROM.h>
#if BoardType == 3
#else
#include <SPI.h>
#endif
#if ISIP == 1
#endif
#if BoardType == 3
WiFiUDP Udp;
WiFiUDP SendPort;
#else
EthernetUDP Udp;
#endif
#if BoardType == 3
void resetFunc() {
  ESP.restart();
#else
#endif
void setup() {
#if BoardType == 3
  EEPROM.begin(256);
#endif
#if ISIP == 1
    EEpromVersion=22;
#if BoardType == 3
    delay(500);
#else
#endif
  Udp.setTimeout(0);
  delay(1000);
SendConnect();
#else
  Serial.flush();
  delay(1000);
#endif
HSSetup();
void loop(){
  HSloop();
#if ISIP == 1
  UDPCheck();
#endif
void SendConnect()
#if ISIP == 0
#else
    Udp.endPacket();
      Udp.endPacket();
#endif
#if ISIP == 1
void UDPCheck(){
  if(packetSize)
 #if BoardType == 3
    Udp.read();
    Byte2 = Udp.read();
    Udp.read();
    Udp.read();
    Udp.read();
    DataEvent();
    #else
    Udp.read();
    Byte2 = Udp.read();
    DataEvent();
#endif
#else
    delay(17);
    Serial.read();
    DataEvent();
#endif
D Disconnect
r reset
K Keepalive
C Connect request
void DataEvent() {
#if ISIP == 1
#endif
    switch (Byte2) {
    case 'c':
      IsConnected = true;
      break;
    case 'C':
#if ISIP == 1
      Udp.print(" ");
      Udp.print(Version);
      Udp.endPacket();
      delay(100);
      Udp.endPacket();
#else
      Serial.print(" ");
      delay(100);
#endif
      delay(100);
      break;
    case 'K':
      delay(200);
#if ISIP == 1
      Udp.endPacket();
#else
#endif
      break;
      case 'r':
      delay(200);
      break;
    case 'O':
      break;
    case 'D':
      break;
#if ISIP == 1
  Udp.print(" API ");
  Udp.print(Device);
  Udp.print(" ");
  Udp.print(Data);
  Udp.endPacket();
#else
  Serial.print(" ");
#endif
#if ISIP == 1
  Udp.print(" API ");
  Udp.print(Device);
  Udp.print(" ");
  Udp.print(Data);
  Udp.endPacket();
#else
  Serial.print(" ");
#endif
#if ISIP == 1
  Udp.print(" API ");
  Udp.print(Device);
  Udp.print(" ");
  Udp.print(Data);
  Udp.endPacket();
#else
  Serial.print(" ");
#endif
#if ISIP == 1
  Udp.print(" API ");
  Udp.print(Device);
  Udp.print(" ");
  Udp.print(Data);
  Udp.endPacket();
#else
  Serial.print(" ");
#endif
Try changing
to
pinMode(FogButtonPin, INPUT_PULLUP);
Greig.
Old July 19th, 2017, 03:00 PM
Seer Deluxe
Quote:
Originally Posted by enigmatheatre View Post
Try changing
to
Greig.
Tried that too Greig and nothing...I also changed it on the debounce sample code and it still worked with that when it was either INPUT or INPUT_PULLUP. Hmph.
I also tossed in the HSSetup()
and also did it in the debounce code and I could read from the serial monitor the code tossed in Serial.println("Testing debug line"); in the debounce code. I can see it come up in the serial monitor for the debounce code however for the API code nothing comes up in the serial monitor. I'm not getting why the code is not functioning the same as a non API code...
Old July 19th, 2017, 07:04 PM
Seer Master
Are you running these tests on a single board or do you have two boards? If multiple, are they the same type of board?
Old July 24th, 2017, 12:10 AM
Seer Deluxe
Quote:
Exact same NodeMCU board. Just loading the debounce sketch to it, it works, then load the HS API with the "same" sketch and it doesn't work...I have no idea.
HTML code is Off
Custom Control - Adding russr999 HS3 Plug-In Development 0 April 16th, 2016 08:01 AM
Adding more custom pages happnatious1 HS3 / HS3PRO Discussion 1 September 18th, 2014 10:12 PM
Adding custom icon??? Rotech ACRF Processor (3P) 1 May 29th, 2012 07:47 AM
Adding custom webpages jls944 HomeSeer General Discussion Area 2 March 8th, 2008 10:45 PM
Adding more than 4 custom web pages jayfro HS2 / HSPRO 3 February 2nd, 2006 06:12 PM
