Fibaro Flood Sensor Z-Wave error and issues
    #16
    I am seeing the EXACT same behavior described by randman. The ONLY things that report are:
    - Water Notification (Also sets to Unknown when polled)
    - Temperature
    - Home Security (Goes to tamper when moved and unknown when polled)
    - Battery (only have gotten a single update)
    This sucks! Is there no HomeSeer 3 support for this device? How do you get a heartbeat to determine if this thing is working?
    Jean-Marie G. Vaneskahian
    jean@vaneskahian.com
      #17
      Bump...
      Exact same problem in my implementation as jeanv and others.
      Current Date/Time: 2018-02-03 17:45:41
      HomeSeer Version: HS3 Standard Edition 3.0.0.368
      Operating System: Microsoft Windows 10 Home - Work Station
      System Uptime: 9 Days 6 Hours 34 Minutes 48 Seconds
      IP Address: 192.168.0.3
      Number of Devices: 118
      Number of Events: 24
      Available Threads: 1023
      Enabled Plug-Ins
      1.1.17344.311: MyQ
      1.0.0.5: Restart
      3.0.1.130: Z-Wave
        #18
        Originally posted by MikeO3 View Post
        Bump...
        You should try removing the device and then upgrade to the latest Z-Wave plugin and then add it back in and test.
          #19
          Thanks for the guidance...
          I have removed, updated and re-added. Will advise if polling and updates function or not in a few days.
          Just FYI reason why I did not update to latest Z-Wave plugin:
          • Release notes were not indicative of an update which fixes this issue.
          • Release notes are not updated to the latest .190 published version.
          • Updating for the sake of upgrading always causes me other issues.
            #20
            A few days have past since the Z-Wave plugin update and still no polling on the temperature. The battery is reporting and the unknown is gone and reporting ok for the alarms. I'll test with some water tomorrow.
              #21
              Thanks for the update... It is disappointing that it does not register better with HS3 and the updated Z-Wave pluging.
                #22
                I am not sure why you guys are not getting the right child devices. I am on z-wave 190 and HS 402 and I get the following devices. It is also the 300 series fibaro. Don't know if that makes any difference or not.
