Go Back   HomeSeer Message Board > Ultilities (Plug-ins) > Utilities Discussion > Tasker Plugin (3P)
Tasker Plugin (3P) Discussions related to the Tasker plugin by Tonlof.
Old April 18th, 2016, 10:05 AM
dondi dondi is offline
Setup problems with the plugin
Hey
I'm trying to config the plugin.
I followed the online manual https://docs.google.com/document/d/1...Ro96vbdGc/edit
And got stuck.
1. I don't know from where I need to get update_overide.txt file
2. I don't have "tools" menu for broadcasting ip.
Any help will be great.
Old April 18th, 2016, 10:36 AM
waynehead99 waynehead99 is offline
Super Seer
I think it's a little dated. The plugin is available under manage plugins.
Old April 19th, 2016, 02:51 AM
Is there some updated doc for configuring this plugin?
All I need to configure is to trigger some on/off switches on HS3 from tasker.
Old April 19th, 2016, 03:30 AM
tonlof's Avatar
tonlof tonlof is offline
unfortunately not, I'm working on a new version of the plugin and engine so most focus is on this. But there is examples in the HS3 Samples tab in Tasker. Off & On, Just change the %HsRef number to your device.
Tasker Plugin / Speech Droid
Tonlof | Sweden
Old April 20th, 2016, 12:58 PM
Tried it and no go.
I've looked in the plugin settings for my device number under "list device ref"
and entered the number in the "off" example on tasker and ran it, nothing happend.
tried to ran an event with %HSCommand, nothing happened as well.
Any help will be appreciated
Old April 20th, 2016, 02:09 PM
tonlof's Avatar
Tried it and no go.
Could you start the plugin in debug / console mode and see if there is any activity when you run the command?
Old April 20th, 2016, 03:34 PM
The debug is active, Where can I find the file?
Old April 20th, 2016, 03:42 PM
tonlof's Avatar
I think you enabled the debug from tasker plugin? If yes, you will find it here. C:\Program Files (x86)\HomeSeer HS3\Logs\tasker
You can also see the live traffic if you enable the "Developer Mode" under plugin page but you need to restart the plugin so it open the console window.
Old April 20th, 2016, 05:27 PM
Eman Eman is offline
Tried it and no go.
Hi dondi,
The first time you use this plugin it can be abit confusing. What is referred to as "device ref list" is a list of all devices already in HomeSeer. You may need to create your own but you can also use some of those if you strip off the replacement variables. In other words you need the number only if you are not scripting.
Look at this post here for an easy startup: http://board.homeseer.com/showthread.php?t=174452
Sometimes it also helps if you take screenshots of the problems you are facing ("A picture can tell a thousand words").
Note: I assume that your device (phone or tablet) is already connected to HomeSeer.
Eman.
Old April 21st, 2016, 04:48 AM
ok
i've checked the debug log after sending my command and I sew 2 new entries
"21/04/2016 11:47:41 - DEBUG: strword=tab1
21/04/2016 11:47:42 - DEBUG: strword=tab1"
i've attached 2 screenshots of my config for my "living room light" switch
Old April 21st, 2016, 06:22 AM
ok
Ok dondi,
For each of the events you create from the phone or from HomeSeer, there has to be a trigger. So if you are creating events to HomeSeer can you please structure your events like in the examples in the link I posted above. In regards to devices, they can eigther have an ON/OFF (1 or 0)or a status value say 0-100 like you are trying to do.
In order for your events to react in HomeSeer from the phone please setup your Tasker events like in this link: http://board.homeseer.com/showthread.php?t=174452
If you click on the (any) device names on the HomeSeer web page for each device created in HomeSeer you see the device settings. So if you click on the advanced button you can see the values and strings used for each particullar device.
Expeliment with the examples and you will soon see how it's done and then you can move on to scripting. And also read through the other (Tasker) threads for some good ideas.
I hope this helps.
Eman.
Old April 21st, 2016, 09:14 AM
Hey Eman
for now i'm trying to control ON/OFF, for my "living room light"
the REF is 33 and the on/off is 0/100 , I changed the values in tasker to 100 for on.
and still nothing is happening.
I'm suspecting that my phone isn't connected properly to HS.
because now there is no new entry in the debug after sending the command.
Old April 21st, 2016, 10:50 AM
Hey Eman
Ok,
In Tasker add another command at the bottom of your event:
%HSCommand to DeviceUpdate
This is the trigger which makes the event fire.
If settings in tasker went well then everything should work.
Again follow the examples in the link above to create your events.
NOTE: when creating devices they should be referenced in Tasker just like in the examples of devices created with the Tasker plugin. Thus they must exist first in HomeSeer.
Eman.
Old April 21st, 2016, 11:22 AM
Hi dondi,
The attached image is an example for charging the phone
Eman.
Old April 21st, 2016, 11:55 AM
The image did not upload!
Eman.
Old April 21st, 2016, 04:55 PM
Hi dondi,
I have tested the device the way you want to control it and everything works with your kind of setup. You are wright to say that your phone is not connected to HomeSeer.
Did your settings confirm that your are connected to WiFi or WAN? during Tasker setup?
Eman.
Old April 21st, 2016, 05:08 PM
Hi dondi,
I have tested the device the way you want to control it and everything works with your kind of setup as long as you add the last Variable " %HSCommand To DeviceUpdate" And use "off" for turning the light off (I think this may depend on the type of controller. I tested with X10).
Eman.
Old April 22nd, 2016, 12:47 AM
Hey Eman
as I said before, I think that the problem is in the phone connection to HS.
I tried to add the %HSCommand and still nothing happened.
where can I verify the connection settings between my phone to HS?
Old April 22nd, 2016, 02:03 AM
Hey Eman
During setup on the phone itself you get pop up screens where you imput your connection information
Did use this document: https://docs.google.com/document/d/1...t?pref=2&pli=1 durind intial setup? On the phone in Tasker you would run the task with a star where it says "run me". Click on it to open it up and press the play play button on the left at the bottom and follow the instructions. If everything goes well then you are good to go but try also to let the firewall to allow the plugon in HomeSeer if on Windows.
Eman.
Old April 22nd, 2016, 02:39 AM
tonlof's Avatar
Hi dondi, how are you connected.
wifi on same network as Homeseer, outside homenetwork, or do you use myhs service to login?
In Tasker folder on your Android, there is some configuration files.
Could you share these but mask your private data.
hs3_connection.dat
myhs_connection.dat
ssid.dat
Migration / RFXCOM plugin setup problems JWD RFXCOM Plug-In (3P) 9 November 2nd, 2012 01:01 PM
IR Setup Problems in HS2 ncampbell HS2 / HSPRO 0 August 31st, 2005 02:07 PM
Problems with setup picta Hauppauge Capture (3P) 4 February 15th, 2005 12:42 AM
Setup problems pebaugh Web Server and Interface 3 May 18th, 2002 10:21 PM
Setup problems pebaugh Web Server and Interface 0 January 1st, 1970 12:00 AM
