Go Back   HomeSeer Message Board > Ultilities (Plug-ins) > Utilities Discussion > Tasker Plugin (3P)
Tasker Plugin (3P) Discussions related to the Tasker plugin by Tonlof.
Old May 21st, 2016, 08:31 AM
jryanishere jryanishere is offline
Tasker Setup for HS3 not working
I am following the directions here: https://docs.google.com/document/d/1...Ro96vbdGc/edit
And after I download and run the Setup Tasker for HS3, it says it's running and to please wait. Nothing happens. It's been a half hour and nothing happened. Nothing showed up in my projects folder and I ran a search in ES File Explorer and none of the file noted in the guide were installed.
It looks like the server it's looking for is down.
Can I just get the zip file from somewhere and install it manually?
Old May 21st, 2016, 10:01 AM
tonlof's Avatar
tonlof tonlof is offline
Hi, I will check the server if there is any issue.
Tasker Plugin / Speech Droid
Tonlof | Sweden
Old May 21st, 2016, 10:23 AM
tonlof's Avatar
It seems to be something wrong with the dyndns service I'm using.
Send me an PM with your emailaddress if you want me to send the tasker files.
Old May 21st, 2016, 10:40 AM
Sent. It's the same as my name here with @gmail.com
Old August 16th, 2017, 04:08 AM
thierryp44 thierryp44 is offline
InstalTasker HS3 problem
Hi, I also have the same problem. Can you send me the files?
Old August 16th, 2017, 07:01 AM
tonlof's Avatar
Hi, you can download the file from this post. https://forums.homeseer.com/showpost...41&postcount=7
ADIOcelot Setup not working kamalesh ADIOcelot 3 December 14th, 2009 12:52 AM
Setup not working marios HS2 / HSPRO 8 December 8th, 2009 04:12 PM
HST working but vanished from setup Gerard HSTouch™ 2 October 19th, 2009 04:36 PM
Working setup for AP800 Rotech Voice Recognition (ASR) Hardware 8 July 19th, 2008 02:51 PM
XMLTV setup not working for me hec1152 HSTV 8 January 28th, 2004 08:15 AM
