Go Back   HomeSeer Message Board > Ultilities (Plug-ins) > Utilities Discussion > Tasker Plugin (3P)
Tasker Plugin (3P) Discussions related to the Tasker plugin by Tonlof.
Old April 19th, 2017, 06:35 AM
MorkaiTheWolf's Avatar
MorkaiTheWolf MorkaiTheWolf is offline
Communication Problems from HS to Tasker
First, I wanna give a big shout out for this awesome plugin. I've been able to do a lot of awesome things on it but I've apparently run into a situation and need a bit of guidance.
I've been trying to get two way communication working between my HS3 system and my mobile phone. When I'm on the wifi at home, everything works flawlessly both ways.
Issue: When I'm off the home wifi, I can receive messages from HS3 to my mobile device (as seen by testing control through the tasker device to send commands such as 'Vibrate' to the mobile device) but I am unable to receive messages on HS3 from tasker on mobile (such as trying to change a state of a device).
To not spam a wall of useless information, what do you think would be most helpful to start the troubleshooting process?
System Details
Current Date/Time: 4/19/2017 5:16:31 AM
HomeSeer Version: HS3 Standard Edition 3.0.0.297
Operating System: Microsoft Windows 10 Home - Work Station
System Uptime: 1 Day 20 Hours 38 Minutes 41 Seconds
IP Address: 192.168.1.192
Number of Devices: 104
Number of Events: 50
Available Threads: 200
Enabled Plug-Ins
2.0.44.0: BLBackup
2.0.19.0: BLOccupied
3.6.5.0: Harmony Hub
3.0.0.75: HSTouch Server
3.0.0.13: ImperiHome
3.0.0.27: MediaController
3.0.1.52: PHLocation
3.0.3.3: Tasker Plugin
3.0.1.93: Z-Wave
Tasker task:
Variable Set:
Name: %HSSetdevicestraing To Value 2
Variable Set:
Name: %HSSetdevicevalue To 50
Variable Set:
Name: %HsRef To 275
Variable Set:
Name: %HSCommand To DeviceUpdate
Result when on WiFi:
Apr-19 5:21:50 AM Device Control Device: Tasker Tasker Plugin Test Device to Value 2 (50) by/from: CAPI Control Handler
Device state successfully changes.
Tasker Logs:
20170419 05.32.00 E Start    ID0:0.0  TaskService
20170419 05.32.01 T Running  ID177    TestTasker
20170419 05.32.01 A OK       ID177.1  TestTasker.Var Set, %HSSetdevicestring=Value 2
20170419 05.32.01 A OK       ID177.2  TestTasker.Var Set, %HSSetdevicevalue=50
20170419 05.32.01 A OK       ID177.3  TestTasker.Var Set, %HsRef=275
20170419 05.32.01 A OK       ID177.4  TestTasker.Var Set, %HSCommand=DeviceUpdate
20170419 05.32.01 T ExitOK   ID177    TestTasker
20170419 05.32.01 P Instant  ID103    HS Device Trigger
20170419 05.32.01 P Instant  ID110    HS Command trigger
20170419 05.32.01 T Running  ID101:2  Anon
20170419 05.32.01 T Running  ID75:3   Anon
20170419 05.32.01 T Running  ID94:4   HS3Post
20170419 05.32.01 A OK       ID75:3.1 Anon.Perform Task, HS3Post
20170419 05.32.01 T ExitOK   ID75:3   Anon
20170419 05.32.01 A OK       ID94:4.1 HS3Post.Var Set, %newline=
20170419 05.32.01 T RejCopy  ID94     HS3Post
20170419 05.32.01 A Err      ID101:2.1 Anon.Perform Task, HS3Post
20170419 05.32.01 T ExitErr  ID101:2  Anon
20170419 05.32.01 A OK       ID94:4.2 HS3Post.Generate timecode
20170419 05.32.01 A OK       ID94:4.3 HS3Post.Read Line, %connection_method=direct
20170419 05.32.01 A OK       ID94:4.4 HS3Post.Read File, %connection=Android test test ..
20170419 05.32.01 A IfFail   ID94:4.5 HS3Post.Read File, %connection=Android test test ..
20170419 05.32.01 A OK       ID94:4.6 HS3Post.Var Split, %connection=Android test test ..
20170419 05.32.01 A OK       ID94:4.7 HS3Post.Read Line, %ssid_saved=XBOXLIVE
20170419 05.32.01 A OK       ID94:4.8 HS3Post.Read Line, %localip=192.168.1.192:81
20170419 05.32.01 A IfFail   ID94:4.9 HS3Post.Var Set, %protocol=%protocol
20170419 05.32.01 A OK       ID94:4.10 HS3Post.Var Set, %protocol=https://
20170419 05.32.01 A OK       ID94:4.11 HS3Post.Var Convert, %code=MTQxNzk2ODAyNTc0MT..
20170419 05.32.01 A IfFail   ID94:4.12 HS3Post.Var Set, %HSSetdevicestring=Value 2
20170419 05.32.01 A IfFail   ID94:4.13 HS3Post.Var Set, %HSSetdevicevalue=50
20170419 05.32.01 A IfFail   ID94:4.14 HS3Post.Var Set, %HSdata=null
20170419 05.32.01 A IfFail   ID94:4.15 HS3Post.Flash
20170419 05.32.01 A OK       ID94:4.16 HS3Post.For, %testdata=1
20170419 05.32.02 A IfFail   ID94:4.17 HS3Post.Flash
20170419 05.32.02 A OK       ID94:4.18 HS3Post.Test Net, %ssid_test=XBOXLIVE
20170419 05.32.02 A OK       ID94:4.19 HS3Post.If
20170419 05.32.02 A OK       ID94:4.20 HS3Post.Read Line, %ssl=off
20170419 05.32.02 A OK       ID94:4.21 HS3Post.Var Set, %protocol=http://
20170419 05.32.02 A IfFail   ID94:4.22 HS3Post.Var Set, %protocol=http://
20170419 05.32.02 A OK       ID94:4.23 HS3Post.Read File, %connection=Android test test ..
20170419 05.32.02 A OK       ID94:4.24 HS3Post.Var Split, %connection=Android test test ..
20170419 05.32.02 A OK       ID94:4.25 HS3Post.Send data till HomeSeer
20170419 05.32.02 A Disabled ID94:4.26 HS3Post.Flash
20170419 05.32.02 A OK       ID94:4.27 HS3Post.Else
20170419 05.32.02 A OK       ID94:4.31 HS3Post.Goto
20170419 05.32.02 T Running  ID80:5   Clear_Variables
20170419 05.32.02 A OK       ID94:4.38 HS3Post.Continue
20170419 05.32.02 A OK       ID94:4.39 HS3Post.Read File, %httprespond=%httprespond
20170419 05.32.02 A Disabled ID94:4.40 HS3Post.Delete File
20170419 05.32.02 A IfFail   ID94:4.41 HS3Post.Flash
20170419 05.32.02 A IfFail   ID94:4.42 HS3Post.Show Scene
20170419 05.32.02 A IfFail   ID94:4.43 HS3Post.Element Text
20170419 05.32.02 A IfFail   ID94:4.44 HS3Post.Stop
20170419 05.32.02 A OK       ID94:4.45 HS3Post.Stop
20170419 05.32.02 T ExitOK   ID94:4   HS3Post
20170419 05.32.02 A OK       ID80:5.1 Clear_Variables.Var Clear, %HSCommand=%HSCommand
20170419 05.32.02 A OK       ID80:5.2 Clear_Variables.Var Clear, %HSdata=%HSdata
20170419 05.32.02 A OK       ID80:5.3 Clear_Variables.Var Clear, %HSSetdevicestring=%HSSetdevicestring
20170419 05.32.02 A OK       ID80:5.4 Clear_Variables.Var Clear, %HSSetdevicevalue=%HSSetdevicevalue
20170419 05.32.02 A OK       ID80:5.5 Clear_Variables.Var Clear, %HsReplace=%HsReplace
20170419 05.32.02 A OK       ID80:5.6 Clear_Variables.Var Clear, %HsRef=%HsRef
20170419 05.32.03 T ExitOK   ID80:5   Clear_Variables
20170419 05.32.09 E Stop     ID0:0.0  TaskService
When performing the same command off wifi:
No state change. Provided the tasker logs below. Do not see any events logged in HS3.
20170419 05.25.46 E Start    ID0:0.0  TaskService
20170419 05.25.47 T Running  ID177    TestTasker
20170419 05.25.47 A OK       ID177.1  TestTasker.Var Set, %HSSetdevicestring=Value 2
20170419 05.25.47 A OK       ID177.2  TestTasker.Var Set, %HSSetdevicevalue=50
20170419 05.25.47 A OK       ID177.3  TestTasker.Var Set, %HsRef=275
20170419 05.25.47 A OK       ID177.4  TestTasker.Var Set, %HSCommand=DeviceUpdate
20170419 05.25.47 T ExitOK   ID177    TestTasker
20170419 05.25.47 P Instant  ID103    HS Device Trigger
20170419 05.25.47 P Instant  ID110    HS Command trigger
20170419 05.25.47 T Running  ID101:2  Anon
20170419 05.25.47 T Running  ID75:3   Anon
20170419 05.25.47 T Running  ID94:4   HS3Post
20170419 05.25.47 A OK       ID75:3.1 Anon.Perform Task, HS3Post
20170419 05.25.47 T ExitOK   ID75:3   Anon
20170419 05.25.47 A OK       ID94:4.1 HS3Post.Var Set, %newline=
20170419 05.25.47 T RejCopy  ID94     HS3Post
20170419 05.25.48 A Err      ID101:2.1 Anon.Perform Task, HS3Post
20170419 05.25.48 T ExitErr  ID101:2  Anon
20170419 05.25.48 A OK       ID94:4.2 HS3Post.Generate timecode
20170419 05.25.48 A OK       ID94:4.3 HS3Post.Read Line, %connection_method=direct
20170419 05.25.48 A OK       ID94:4.4 HS3Post.Read File, %connection=Android test test ..
20170419 05.25.48 A IfFail   ID94:4.5 HS3Post.Read File, %connection=Android test test ..
20170419 05.25.48 A OK       ID94:4.6 HS3Post.Var Split, %connection=Android test test ..
20170419 05.25.48 A OK       ID94:4.7 HS3Post.Read Line, %ssid_saved=XBOXLIVE
20170419 05.25.48 A OK       ID94:4.8 HS3Post.Read Line, %localip=192.168.1.192:81
20170419 05.25.48 A IfFail   ID94:4.9 HS3Post.Var Set, %protocol=%protocol
20170419 05.25.48 A OK       ID94:4.10 HS3Post.Var Set, %protocol=https://
20170419 05.25.48 A OK       ID94:4.11 HS3Post.Var Convert, %code=MTQxNzk2NzY3MDYyMz..
20170419 05.25.48 A IfFail   ID94:4.12 HS3Post.Var Set, %HSSetdevicestring=Value 2
20170419 05.25.48 A IfFail   ID94:4.13 HS3Post.Var Set, %HSSetdevicevalue=50
20170419 05.25.48 A IfFail   ID94:4.14 HS3Post.Var Set, %HSdata=null
20170419 05.25.48 A IfFail   ID94:4.15 HS3Post.Flash
20170419 05.25.48 A OK       ID94:4.16 HS3Post.For, %testdata=1
20170419 05.25.48 A IfFail   ID94:4.17 HS3Post.Flash
20170419 05.25.48 A OK       ID94:4.18 HS3Post.Test Net, %ssid_test=<unknown ssid>
20170419 05.25.48 A OK       ID94:4.19 HS3Post.If
20170419 05.25.48 A OK       ID94:4.27 HS3Post.Else
20170419 05.25.48 A IfFail   ID94:4.28 HS3Post.Send data till HomeSeer
20170419 05.25.52 A ErrIgnore ID94:4.29 HS3Post.Send data till HomeSeer
20170419 05.25.52 A OK       ID94:4.30 HS3Post.End If
20170419 05.25.52 A IfFail   ID94:4.31 HS3Post.Goto
20170419 05.25.52 A OK       ID94:4.32 HS3Post.Stop
20170419 05.25.52 T ExitOK   ID94:4   HS3Post
20170419 05.25.54 E Stop     ID0:0.0  TaskService
This is from running the same event on and off wifi. The only difference I'm really seeing is that at the end of the successful one, it clears all the variables but on the non-successful, it just exits.
Old April 19th, 2017, 11:29 AM
tonlof's Avatar
tonlof tonlof is offline
Hi Brian, it looks like you are connecting to your local ip 192.168.1.192:81 even when wifi is offline.
Could you check hs3_connection.dat file in the tasker folder.
Line 1 = Your Name
Line 2 = Username
Line 3 = Password
Line 4 = url to wan ip of your router including port.
Line 5 = on = SSL ON, off=No SSL
You can also active more debugging by setting variable %Debug to 1
Tasker Plugin / Speech Droid
Tonlof | Sweden
Old April 19th, 2017, 08:51 PM
Line 1 = Your Name
Line 2 = Username
Line 3 = Password
HS3_Connection.dat:
Android
test
test
desktop-nuc.duckdns.org:4444
on
I just tried flipping SSL to off and now it appears to be sending just fine when I'm off wifi.
Old April 20th, 2017, 12:33 PM
tonlof's Avatar
HS3_Connection.dat:
Android
test
test
on
Great that you found it out.
Old May 5th, 2017, 12:24 PM
khriss75 khriss75 is offline
But is possible to use SSL for a little more security?
Old September 28th, 2017, 03:24 AM
I'm honestly not sure. I haven't gotten to work for me, reliably, with SSL on.
Old September 28th, 2017, 07:23 AM
Eman Eman is offline
Hello,
There is also a problem here "Name: %HSSetdevicestraing To Value 2" in you first post. That will also cause things not to work.
Eman.
Old September 28th, 2017, 09:55 AM
Originally Posted by Eman View Post
Hello,
Eman.
Yeah, I noticed that earlier but that was a spelling error in the post. If you look at the Tasker log, it's showing correctly. Just an instance of me typing and not catching my errors. :P
Old October 2nd, 2017, 01:08 PM
tonlof's Avatar
Newer Android versions & tasker does not accept the certificate from Homeseer
Tasker wljohnson05 Tasker Plugin (3P) 8 August 23rd, 2014 02:53 PM
ISY communication problems jwshome2 ISY Plug-in Beta (3P) 2 November 21st, 2012 06:18 PM
Communication problems in a previously stable Z wave network kbrady HS2 / HSPRO 0 December 17th, 2011 12:39 AM
VRCS4-1LX causing communication problems Thrag HomeSeer Z-Wave Plug-in 1 October 30th, 2011 03:50 PM
Communication Problems azfrankp HS2 / HSPRO 6 March 17th, 2011 06:15 PM
