Is there a free weather plugin?
    I just need the outside temperature. Is there a plugin that'll do that for free?
    Jeff Farmer's weatherXML. Overkill, but it will do what you need. It's in the plugin interface page.
      Yeah, that's overkill for me. I ended up writing a little script to do the job. Here it is in case anyone else wants a free quick way to pull in weather info (I only need outside temperature right now, but this can easily be modified to pull in other info as well) -
      If anyone's interested, I'll provide more information, but you basically create a Virtual Device with a single status and note down its Reference ID. Then, create an Event to run as often as you want to execute the below script (update the first few lines to suit your needs) -
      Imports System.Diagnostics
      Sub Main(parm as object)
      	Dim DevRef AS Integer = 338 'Virtual Device Reference ID
      	Dim sLocation AS String = "91423,us" 'Your location
      	Dim sAPPID AS String = "xxxxxxxxxxxxxxx" 'Get this API key from  http://openweathermap.org/api
      	Dim sTempUnit AS String = "F"
      	Dim oProcess As New Process()
      	Dim oStartInfo As New ProcessStartInfo("PowerShell.exe", "-Command ""(Invoke-WebRequest -usebasicparsing 'api.openweathermap.org/data/2.5/weather?q=" + sLocation + "&APPID=" + sAPPID + "&mode=json&units=imperial' | ConvertFrom-Json).main | select temp | ft -hide""")
      	oStartInfo.UseShellExecute = False
      	oStartInfo.RedirectStandardOutput = True
      	oProcess.StartInfo = oStartInfo
      	oProcess.Start()
      	Dim sOutput As String
      	Using oStreamReader As System.IO.StreamReader = oProcess.StandardOutput
      		sOutput = oStreamReader.ReadToEnd()
      	End Using
      	hs.writelog("Temperature", sOutput)
      	hs.SetDeviceValueByRef(DevRef,CDbl(sOutput),true)
      	hs.SetDeviceString(DevRef,sOutput + " º" + sTempUnit,true)
      End Sub
        I am looking for some weather plugin as well but want a bit more out of it... current conditions, couples days in advance weather and weather alerts. I'd like to use an existing plugin but no way I am paying $20 a month for an API key. (I think that's how it works anyway).
        Nice script. I see it's pulling from http://openweathermap.org/api Would I be able to get what I want from Open Weather for free you think?
        I am evaluating Homeseer at the moment. Only just got it up and running so still playing around with it. Hoping it can replace my Smartthings hub.
          Actually, I found this PowerShell script here
          http://michaelhalpin.azurewebsites.n...-co-ordinates/
          Now I have to figure out how to get the data into Homeseer
            You don't need a $0/month subscription for Weat.herXML. It can be used with free sources. Since you are in Canada, there's also ChrisGo's Environment Canada plugin. See here: https://forums.homeseer.com/showthread.php?t=169462 and here: https://sites.google.com/site/b123cdd/.
            Cheers
            Al
              Thank you. I just spotted those after I posted.
                Cheers
                Al
                Another vote for the WeatherXML plugin. It is probably one of the most sophisticated plugins period. Lots of things to configure. For example if you use the PHlocation plugin too, you can setup actions based on the weather where you are, not just where your house is.
                It is also mostly a set and forget plugin that seems quite stable most of the time.
                It does not hurt that the Author is closely tied to Homeseer (the company), and is quite responsive to issues.
                  Greg (Wadenut) has a great script which uses Enivionment Canada for weather information.
                  Even though I use WeatherXML, I find this script more accurate. Very simple to setup...
                  https://board.homeseer.com/showthread.php?t=151302
                  Robert
