OMNI Plugin v3.0.2.4
    v3.0.2.4 was released to the updater today. It might take a day or so before it shows up in the list.
    Changes in this version:
    • Fixed - Still getting a warning registering duplicate "Logs" page (@Pete)
    • Fixed - Logging checkbox not remembering state on restart (@Pete)
    • Fixed - Tab number not being honored on postback (@rmasonjr)
    • Fixed - Event trigger "any user except" not triggering (@lakemirror)
    • Changed - Remove TCP/UDP option in config screen and always default to TCP (all)
    • Fixed - Plugin now displays OMNI in upper-left of HS page (Scott)
    Always make a backup of your system before loading a new version.
    Post any issues you have with this version in this thread.
    HS4Pro on a Raspberry Pi4
    HSTouch Clients: 1 Android
    The OMNI plugin is now in the updater and is ready for download...
      Reserved 2
        Thank you Rob. Updated this morning, Wednesday 27th of September, 2017.
        Sep-27 9:12:19 AM Info Plugin OMNI has connected. IP:127.0.0.1:59504
        Sep-27 9:12:22 AM Plug-In Finished initializing plug-in OMNI
        Sep-27 9:12:27 AM OMNI -->Reading configuration...
        Sep-27 9:13:02 AM OMNI -->Reading properties...
        Sep-27 9:13:03 AM OMNI All configuration and properties retrieved.
        Sep-27 9:13:03 AM OMNI Requesting Area status...
        Sep-27 9:13:04 AM OMNI Requesting Output status...
        Sep-27 9:13:07 AM OMNI Requesting initial system troubles
        Sep-27 9:13:07 AM OMNI Synchronizing OMNI devices with HomeSeer...
        Plugin Version v3.0.2.4
        No issues with the update.
          Checked the logging switch and it is working now.
          Turned debug logging.
          I can confirm that debug / logging is working now.
          9/27/2017 2:19:42 PM [2] [Zone [14] Humidity-->52]
          9/27/2017 2:19:42 PM [2] [Humidity Zone 14 changed status. Reading=[52]]
          9/27/2017 2:19:42 PM [2] [---->Auxillary]
          9/27/2017 2:19:42 PM [2] [UNSOLICITED: ExtendedStatus]
          9/27/2017 2:19:12 PM [2] [Zone [14] Humidity-->53]
          9/27/2017 2:19:12 PM [2] [Humidity Zone 14 changed status. Reading=[53]]
          9/27/2017 2:19:12 PM [2] [---->Auxillary]
          9/27/2017 2:19:12 PM [2] [UNSOLICITED: ExtendedStatus]
          9/27/2017 2:18:12 PM [2] [Zone [14] Humidity-->52]
          9/27/2017 2:18:12 PM [2] [Humidity Zone 14 changed status. Reading=[52]]
          9/27/2017 2:18:12 PM [2] [---->Auxillary]
          9/27/2017 2:18:12 PM [2] [UNSOLICITED: ExtendedStatus]
          9/27/2017 2:10:58 PM [2] [Logging set to DEBUG]
          Tested Omni Plugin in terminal mode.
          1 - shut down HS
          2 - SSH'd to box and ran ./go
          02:24:23:7353:[Info]->Plugin OMNI has connected. IP:127.0.0.1:34850
          Connected to HS.
          02:24:26:1595:[Plug-In]->Finished initializing plug-in OMNI
          I do not see anything else in the console.
          3 - shut down Homeseer 3
          02:28:23:6304:[Shutdown]->-------------------------------------------------------------------
          02:28:23:6308:[Shutdown]-> HomeSeer Successfully Shut Down Now
          02:28:23:6310:[Shutdown]->-------------------------------------------------------------------
          HomeSeer Linux has shut down.
          See nothing else after shutdown of Homeseer.
          4 - Changed - Remove TCP/UDP option in config screen and always default to TCP (all)
          I see that there is no TCP/UDP option.
          5 - Fixed - Plugin now displays OMNI in upper-left of HS page (Scott)
          [ATTACH]63582[/ATTACH]
            Thanks Pete! You're the best!
              Mentioned this in another thread, too, but the "any user except" functionality is working again. Great job.
                Steps to update
                I'm still on the old HAI plugin and ready to install the Omni labeled version. What are the steps involved? Do I disable the old one first, or remove it, or??? I don't want to lose any setting (Panel info, keys, unit settings, etc.)
                  First and foremost, make a backup.
                  Disable the HAI plugin, then load the OMNI plugin from the updater.
                  You will also need your license code
                    Been running v3.0.2.4 for a few days now. Nothing to report at this time!
                      Cloned the mSD card on the Zee first and did the upgrade on the cloned card to be safe. Upgrade went perfectly.
                      Thank You!
                      Now if we could just get audio control added.
                        Thank You!
                        Actually, the wheels are in motion. I dont have the audio hardware, but I have been pouring over the API specs on sending basic commands to zones. What I want to do is get some basic HS Devices built to send the commands and roll it out for you guys to test. Those commands that pass, will be wrapped into the HS event engine for building events for audio control.
                        Stay tuned...
                          Stay tuned...
                          Count me in! I have a Russound CAV6.6.
                          One observation is that the API refers to the rooms/keypads as Zones 1,2,4... and the Inputs as Source 1,2,3,... However, within the CAV they are named i.e.
                          Zone1 = Kitchen
                          Zone2 = MasterBD
                          Source 1 = XM
                          Source 2 = CD
                          Etc
                          I'm hoping we'll be able to name them in Homeseer and them refer to them them by their names like "Alexa Turn Kitchen Audio ON," Set Kitchen Audio to XM", Set Kitchen Volume to 30%" I'd be real happy with just the basics - On, Off, Source, and Volume.
                            Doing well here Rob with v3.0.2.4.
                            Thank you for the look see at the OmniPro audio stuff.
                            Here while I do stream Internet audio still enjoy my very old music collection such that the OmniPro connection is pure hardware.
                            With multiple source inputs here use little remote controllable touchscreens on thew rack that utilize either Homeseer touch or embedded Squeezeplayer. (and Kodi).
                            Logitech Squeezeplayer while old today is still supported and free these days. You can build a headless RPi Squeezeplayer box and remote control it from Homeseer.
                            Here do subzones of Russound Zones with local audio and testing a Squeezebox player touchscreen in the bathroom these days. Works great.
                              Mason I know how to do a data/config backup [Tools, Setup, Config, & Backup Config] but how do I make a backup of the HAI Plug In? Or does the Config Backup also include the plug in?
