I am looking to build a raspberry pi that uses Python scripts to post device info to an AWS IoT environment. Would it be possible to use a HomeSeer device as the Z-Wave hub and then either configure the HomeSeer hub to publish info to AWS or have the Raspberry Pi retrieve events from the HomeSeer hub and then publish info that way?
Send device info to AWS IoT Cloud
Originally posted by jdeason View PostI am looking to build a raspberry pi that uses Python scripts to post device info to an AWS IoT environment. Would it be possible to use a HomeSeer device as the Z-Wave hub and then either configure the HomeSeer hub to publish info to AWS or have the Raspberry Pi retrieve events from the HomeSeer hub and then publish info that way?
For your project go here : https://flows.nodered.org/node/node-...ib-aws-iot-hub and see if that's what you are looking for
Eman.TinkerLand : Life's Choices,"No One Size Fits All"
