Evolve Lamp Module Failures?
    I have seven Evolve lamp dimming modules that are perhaps five years old. These devices have worked nearly flawlessly for that period on both my HS2 and HS3 systems. Suddenly, within a two week period, 6 of the 7 showed an "unknown" status. Unplugging and re-plugging each of them, followed by a rescan and optimization, brought them back online, though one of them has since reverted to UNKNOWN again. All of them have excellent connections with 30 or more neighbors. Any ideas as to why these would suddenly began behaving strangely?
    HS4Pro on Windows 10
    One install with 2 Ethernet Z-nets
    2nd install with 1 Ethernet Z-net
    300 devices, 250 events, 8 scripts
    6 CT-100 tstats
    Serial IT-100 interface to DSC Panel with 8 wired zones
    18 Fortrezz water sensors & two valve controls
    OK, now seven of the seven are exhibiting the same behavior. As of this moment, two of the seven are showing unknown status. It is just too coincidental that the only seven of these devices I own, which have performed flawlessly for the past five years, suddenly within a two-week period all do the same thing, over and over. What could this be?
    6 CT-100 tstats
      I'm having the same issue with Jasco switches *and* modules. The modules look identical to Evolve.
      Mostly, the radios die, but the last module failed by blowing out the light bulb. On that one the z-wave still (appears to) works and the non z-wave side works, but no joy controlling the z-wave controlled side.
      HomeSeer Version: HS4 Pro Edition 4.2.19.0 (Windows - Running as a Service)
      Home Assistant 2024.3
      Operating System: Microsoft Windows 11 Pro - Desktop
      Z-Wave Devices via two Z-Net G3s
      Zigbee Devices via RaspBee on RPi 3b+
      WiFi Devices via Internal Router.
      Enabled Plug-Ins
      AK GoogleCalendar 4.0.4.16,AK HomeAssistant 4.0.1.23,AK SmartDevice 4.0.5.1,AK Weather 4.0.5.181,AmbientWeather 3.0.1.9,Big6 3.44.0.0,BLBackup 2.0.64.0,BLGData 3.0.55.0,BLLock 3.0.39.0,BLUPS 2.0.26.0,Device History 4.5.1.1,EasyTrigger 3.0.0.76,Harmony Hub 4.0.14.0,HSBuddy 4.51.303.0,JowiHue 4.1.4.0,LG ThinQ 4.0.26.0,ONVIF Events 1.0.0.5,SDJ-Health 3.1.1.9,TPLinkSmartHome4 2022.12.30.0,UltraCID3 3.0.6681.34300,Z-Wave 4.1.3.0
