Or maybe an addition to the existing sticky. I downloaded the trial of WeatherPLUG today. The first thing I did was look in the doc and docs folders. Nothing there. Then I went to Setup|Interfaces and enabled WeatherPLUG. WeatherPLUG enabled but I could see no way to configure it (config button did not appear until I restarted HS, although I did restart after the download from the Updater). Before restarting I thought the issue might be that I was not seeing a config button on the menu since I use DooMenubar. I tried looking for a config page in that. No luck.
Rebooted, and as I noted above I could now get to a config button. The setup is pretty straight-forward, but I could not get the devices for the first station to show up in status, only stations 2 and 3. I could not select any stations at all. Ultimately I found the posts about the missing (in my case) .ocx file and now all is fine.
All of the extra putzing around I did could have been avoided if the key points from the various posts had been in a couple of paragraphs in a sticky on the main page. Might help the next user.
