Text box format
    Text box format
    OK,
    Puling this device in to HSTouch into a text box.
    The data comes in fine but as a single line of text. If I copy the string text from the device and place in note pad etc returns at the end of each song are honored, but not in HSTouch.
    Thoughts?
    In the textbox properties, try putting this in the TEXT entry:
    [$SCRIPT=&hs.DeviceString(317)]
    You will probably need to also set IsHTML = True
    Mike
