Upgraded to HS3 .333 today, and JowiHue stopped working (JowieHue shuts down and restarts over and over).
Tried deleting the bridge and now receives the following faults.
Did also try removing the mentioned Newtonsoft.Json.DLL file, but that creates new errors.
Rolling back until I have a clue of why and how
jul-04 19.12.10
JowiHue
Error: (Bridgescan):====== disable this plugin until the issue is resolved?
jul-04 19.12.10
JowiHue
Error: (Bridgescan):====== Please remove this file and make sure the Newtonsoft.Json.DLL in C:\Program Files (x86)\HomeSeer HS3\bin\JowiHue is present
jul-04 19.12.10
JowiHue
Error: (Bridgescan):====== Probably there is a different version of this file in either C:\Program Files (x86)\HomeSeer HS3 or C:\Program Files (x86)\HomeSeer HS3\bin
jul-04 19.12.10
JowiHue
Error: (Bridgescan):====== The plugin has an issue with a wrong placed Newtonsoft.Json.DLL file
jul-04 19.12.10
JowiHue
Error: (UDPListener):Could not load file or assembly 'Newtonsoft.Json, Version=7.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
jul-04 19.11.39
JowiHue
Warning: MainWatchThread: No bridge found, plugin will scan until found
jul-04 19.12.10
JowiHue
jul-04 19.12.10
JowiHue
jul-04 19.12.10
JowiHue
jul-04 19.12.10
JowiHue
jul-04 19.12.10
JowiHue
jul-04 19.11.39
JowiHue
