Jon00 Event Viewer & Documenter for HS3
    #91
    Originally posted by cheeryfool View Post
    Awesome update Jon. Exactly what I was looking for. Found a couple more events with broken actions that I didn't know were broken. I also found 2 dupe voice commands. One of which I am struggling to remove off the report. I think I need to delete and create the event (it's a simple one). I think this is caused by some spurious behaviour in the event engine when you copy an event that has a voice command. It seems in some cases to be sticky even after you remove or replace the voice command. Sometimes in this case, when you click into the Voice command box, the pop-up contains the original copied value instead of the current replaced value. In any case, not your issue.
    Thanks again for the quick turnaround and great new features.
    Thanks.
    You can also thank Rich for adding the Event Voice Command support.
    Jon
      #92
      Originally posted by jon00 View Post
      Thanks.
      Yes, thanks Rich for adding the voice command to the scripting interface.
      cheeryfool
        #93
        Hello Jon, after installing the lastest update I cant get to bring up the viewer. this is what I get. what am Iam doing wrong?
        Hector
        Win.2003 OS, HS3
        MyTrigger,ACRF2,W800,Zwave
        AP800,Honeywell Stat
          #94
          cheeryfool
            #95
            I have .402, where do u get the .407?
            Hector
            Win.2003 OS, HS3
              #96
              Never mind found it. Thank you.
              Hector
              Win.2003 OS, HS3
                #97
                Feature Request - Split IF / Then during export
                Flinging this out as a possible feature
                Would it be possible to add an option to split the "If" conditions into a separate column from the "Then" actions when exporting to CSV?
                I use CSV regularly....and having them lumped together is a bit of a bummer..would be nice to separate them so they appear separately.
                Thanks for considering this possible addition to yet another OUTSTANDING contribution to the HS community.
                My home is smarter than your honor roll student.
                  #98
                  Thanks very much. Let me take a look to see what can be done.
                  Jon
                    #99
                    V1.0.4 Available
                    Changes since 1.0.3:
                    Feature request:
                    Event triggers and conditions are now split in the generated CSV file.
                    Jon
                      sorry, I have not found the 407 update .. where is this in the UPDATES list?
                        .409 is the latest official beta: https://forums.homeseer.com/showthread.php?t=181241
                        If you don't want to install the beta, stick with V1.0.2 which is also included in the download.
                        Jon
                          Jon
                          A couple of things:
                          1. When I have a scheduled report to show broken events, the "3||Broken" parameter is causing a false positive for a broken event. Could the Broken parameter be ignored in the search perhaps? I already switched to using "Borked" in the event name.
                          2. I'd love to be able to send a pushover message (or I guess email) with a summary of how many events are broken and detail (as an attachment) of what is broken. I tried just sending the eventlisting.txt file as an attachment in Pushover but that seems to only support images currently. I tried an email attachment but that seems to be broken in HS3 .409, which I will report elsewhere.
                          Perhaps the .txt output could be enhanced to show the number of events matching the search criteria out of the total. Something like this:
                          Homeseer 3 Event Report 2/13/2018 08:20:34 AM
                          Sort Order: Event Name - Ascending
                          Search String: 'Broken'
                          Events Matching Search Criteria: 1 / 268
                          And then I could use a script to pull that out of the file header
                          Cheers
                          James
                          cheeryfool
                            I don't quite understand point 1. The event drop-down for broken does just search for 'broken' but I think that was made case sensitive. Are you saying that you have an event which contains the word broken or something else?
                            Jon
                              cheeryfool
                                OK, that makes sense. Never thought of that!
                                I cannot think of an easy way to resolve so suggest you run a script to run a script for your event:
                                    Sub Main(ByVal Parm As Object)
                                        hs.runscriptfunc("Jon00EventViewerASPX.vben", "Report", "3||Broken", False, False)
                                    End Sub
                                I'll look at point 2 when I can.
                                Jon
