PHLocation V1 Plug-In [No Longer in Development - See PHLocation2]
This is a sticky topic.
    Someone posted a link to the backitude apk file, but I cannot find it. A Google search turned up several links to download 5.3. I don't know how legitimate the links are.
    You saved me with that. Just Googling for "Backitude" didn't get anything but when I did it as Backitude 5.3.1, I found the APK on a website. It is clean according to my phone's virus scan.
    I'm back in service. Thanks!
      While you are in there, can you add find my iPhone support with the cloud? And, is there a limit to iCloud accounts? I have 5 accounts with my family... Thanks,
        I'm sure Paul will ask what you mean by this. In essence PHLocation uses "find my iPhone" in order to populate the iOS device for location.
        I don't think 5 iCloud accounts would be a problem, but Paul will have to answer that. I have 2.
          I would love to be able to initiate the find my iPhone sound via the plugin... I believe once you have access that can be done. My wife is constantly looking for her phone - would be great to have that as a button on my HS Touch to play the sound. A text/call won't work if she has it on mute, find my iPhone is the only service that I know that will actually make a noise.
            Sorry, I wasn't thinking about having the phone play a sound, I was just thinking about the map. My bad!
              The plug-in currently supports a maximum of 5 iCloud accounts.
              Paul..
                Yes this is possible.
                I originally intended to add support for sending messages and / or alert sound but I don't believe anyone asked for it so I never added it.
                I just tested it with an iPhone 7 and iPad 4 mini and it works OK so I will add it in the next version.
                Paul..
                  YES! Thanks - I so want a button on my home screen to play the find my iPhone sound - thanks!
                    Hi !
                    I have just got an Samsung S8 and trying to set up Tasker with PHLocator. I have used Geofency on my iPhone earlier, and it works like a charm.
                    I have in tasker a profile which called Home, and it triggers when I leave and reach Home, with an area of 100m. I have a task which sends the HTTP Post to the HS. The url are as follows : http://name@domain.com:password@doma...port/phlcustom
                    It triggers fine, but I got empty data string :
                    Se logdetails :
                    mar-28 07.21.20	 	PHLocation	(httpprocrequest) Time taken to process request = 15,6298 ms.
                    mar-28 07.21.20	 	PHLocation Error	(httpprocrequest) Empty data string!
                    mar-28 07.21.20	 	PHLocation	(httpprocrequest) POST data =
                    mar-28 07.21.20	 	PHLocation	(httpprocrequest) Request Type = POST
                    mar-28 07.21.20	 	PHLocation	(httpprocrequest) RawURL = /phlcustom
                    mar-28 07.21.20	 	PHLocation	(httpprocrequest) User and Password authenticated OK
                    mar-28 07.21.20	 	PHLocation	(httpprocrequest) Request received. Total Req's = 61
                      Originally posted by Xian View Post
                      Hi !
                      Se logdetails :
                      From your post, it appears that you are using Tasker as a geofencing solution. Although the plug-in can support fence data via the custom data feature, I don't believe that anyone has used it in this way.
                      The easiest way to get it working is to emulate another supported gefence user type.
                      Set up a new Gefency user (you could use your old iPhone user if not deleted) and then make Tasker send the data as though it is Geofency.
                      In your http post call the /phlgeofency url and as a minimum you need
                      to pass the following parameter in the request:
                      [id] [name] [entry]
                      [id] is the device id and should match whatever is entered on the geofency root device in the plug-in.
                      [name] is the name of the geofence.
                      [entry] 1=Enter 0=Exit
                      Example:
                      .../phlgeofency?id=1234567890&name=Home&entry=1
                      Try that. If it doesn't work as expected, drop me an email and I'll see if I can help you to get it working.
                      Paul..
                        [id] [name] [entry]
                        Example:
                        Paul..
                        I can't manage to have this to work, what is your email adress ?
                        Sent fra min SM-G950F via Tapatalk
                          My email address is at the top of the user guide or alternatively click my user name whilst logged into this board and you can send an email from there.
                          From a web browser on the same LAN as your HS3 machine, try the following url
                          http://yourhs3server:phlport/phlgeofency?device=1234567890&id=home&name=home&entry=1
                          You should get prompted for user credentials?
                          After entering the PHL credentials, you should get a data accepted message.
                          Unfortunately I don't have an Android device any longer to test Tasker but it should work with an http post task.
                          I can't remember if the credentials are entered in their own fields in Tasker. If not, then you will have to enter the credentials into the url
                          http://username:password@yourhs3server:phlport/phlgeofency?device=1234567890&id=home&name=home&entry=1
                          Paul..
                            I run from a local browser...
                            I got the login prompt. But I got an error. I have tried with :
                            http://192.168.253.4:9123/phlgeofenc...istian&entry=1
                            http://192.168.253.4:9123/phlgeofenc...hjemme&entry=1
                            The devices are as attached in the image.
                            The log is :
                            mar-29 09.32.28	 	PHLocation	(httpprocrequest) Time taken to process request = 28,0002 ms.
                            mar-29 09.32.27	 	PHLocation	(httpprocrequest) GeoFency response = Error! Fence data check type [F] failed.
                            mar-29 09.32.27	 	PHLocation Error	(ProcHttpFenceData) DataCheck Error. Did: Fid:1420 Fname:Christian Ftyp:F Fdir:1 Fpv:GC
                            mar-29 09.32.27	 	PHLocation	(httpprocrequest) Full GET data = id=1420&name=Christian&entry=1
                            mar-29 09.32.27	 	PHLocation	(httpprocrequest) Request Type = GET
                            mar-29 09.32.27	 	PHLocation	(httpprocrequest) RawURL = /phlgeofency
                            mar-29 09.32.27	 	PHLocation	(httpprocrequest) User and Password authenticated OK
                            mar-29 09.32.27	 	PHLocation	(httpprocrequest) Request received. Total Req's = 39
                              Can you try:
                              http://192.168.253.4:9123/phlgeofency?device=1420&id=Christian&name=Christian&entry=1
                              Paul..
                                Got GC data accepted, but find this in the log :
                                PHLocation Warning	(ProcessFenceQueue) No PHL user device found for incoming Fence device ID [1420]!
