I am moving from a vera system. The alarm worked great with it (when vera worked). So I know the alarm is set up correctly. Since vera was next to the panel and the computer with HS3 is not, I have installed a global cache IP2SL to connect the panel to the network and have VSPE emulating a serial port and connecting to the global cache.
Entering all of the info in the plugin and hitting save, then connect, I get the attached picture. It says disconnect panel, which makes me think it is connected, but it doesn't say NX-8 like in the plugin manual. I also cannot get the verify pin code to work even though I am absolutely sure that it is correct.
I have attached a log file picture. It says that the panel time is synced with HS, which makes me think it is connected.
Trying to 'Get Zone or Partition Info' Does nothing.
Can someone point me in the right direction? Thanks!
