Go Back   HomeSeer Message Board > Legacy Software & Plug-ins > Legacy Plug-ins > Legacy HomeSeer Plug-ins > Aprilaire
Old September 4th, 2015, 12:30 AM
cjin cjin is offline
Seer Deluxe
Aprilaire with HS3?
Did anyone find a way to run Aprilaire thermostat with HS3?
Old September 4th, 2015, 06:22 AM
ffneilm ffneilm is offline
Seer
Thinking the same thing.
An aprilaire plugin is the only thing stopping me from switching totally to H3.
Old September 4th, 2015, 09:46 AM
Gunneyk's Avatar
Gunneyk Gunneyk is offline
Seer Deluxe
I have an AprilAire thermostat that came with the house and I would like to replace it but I can't find one I am comfortable with. It displays the outside temperature on the LCD display and the majority of the Z-Wave thermostats do not have this feature. Now I don't really care if the temp is displayed or not but it is my understanding that the unit uses that input (in part) to determine when to kick in the aux heat source since this is a heat pump. I just can't find enough information to determine if the replacement thermostats deal with that regardless of displaying it on the screen. I tracked down the guy who installed the unit and he was clueless.
Andrew J. Kelly
Virginia
Old September 4th, 2015, 07:20 PM
Seer
The outside temp is optional. It will allow you to set the balance point thru the thermostat that determines when the aux heat will run with the compressor shut off. Any thermostat designed for a heat pump will work.
The pluses of the Aiprilaire is that it is modular and has ability to add zones, multiple temp and humidity readings. You can control a whole house humidifier and the biggest plus is the ability to control it from a home automation system.
Old September 5th, 2015, 08:51 AM
Seer Deluxe
Quote:
I am in same situation. How many people have interest in a third party plugin?
Old November 15th, 2015, 12:25 PM
bbuck2002 bbuck2002 is offline
Seer
I am still interested in this, and could help with testing and development. I am unable to upgrade to HS3 because of this one plugin... Is HomeSeer willing to provide the original code for the HS2 plugin? I could probably port it to HS3.
Old November 15th, 2015, 12:35 PM
sparkman's Avatar
sparkman sparkman is online now
OverSeer
Quote:
The source code is available: http://store.homeseer.com/store/Home...ode-P1800.aspx
Cheers
Al
HS3Pro 3.0.0.318 on Jetway JBC501F9Q-Q87-B i7 8GB 1874 Devices, 955 Events, 28 Plugins
Z-Wave 3.0.1.131 Z-Net 105 nodes:Leviton Vizia,Kwikset,FortrezZ Valve/Sensors,Everspring Sensors/Modules/Outlets,CT30 Stats,MIMOLites,Aeotec Smart Switches
RFXCom W800,RFXrec433,RFXtrx433|APCUPSD|Pushover|Squeezebox|weatherXML|HS Phone W2C|APCUPSD|UltraLog
UltraGCIR GC-100|UltraNetcam|UltraPioneer|Ultra1Wire|DSC PC1832|BLLED|BLTVGuide|ImperiHome|jon00 Utilities|MySensors
PHLocation|X10 CM11A IOLinc,etc
Old January 24th, 2016, 08:19 PM
Seer
Dollar Sign Really??
This frustrated me when I saw it, so I am not responding until now.
I might pay $50 or so for a working HS3 Aprilaire plugin, but I sure as **** am not going to spend $100 for the source code of the HS2 version! Who knows if I'd even be able to port it!
Anyway, still on HS2, and looks like I'll be supporting it for quite a while longer. I don't really want to replace a perfectly good Aprilaire thermostat setup.
Old January 24th, 2016, 08:43 PM
sparkman's Avatar
OverSeer
Well, don't shoot the messenger
I'd call HS and see if they will release the code as open source. They've done that for a few other plugins as well.
Cheers
Al
Old January 26th, 2016, 09:16 AM
mattm55 mattm55 is offline
Seer Deluxe
I have an interest in an Aprilaire HS3 plugin myself.
At the present I have a whole house Aprilaire humidifier that I would like to control but the thermostat is a Honeywell wifi. The HW works great except they won't release the API so I'm going to switch to the AA 8800 Thermo and the AA 8811 adapter. The HW uses the Total Connect Comfort and even though someone has done a HS3 plugin, it could change and break with any HW update.
So, count me in for a HS3 plugin. I'm going to get a non-HVAC test environment setup 8800 Therm, 8811 Adapter and 800 Hum connected.
-Matt
Update: Does anyone have a working HS2 Aprilaire plugin working? Screenshots and would grabbing source code might expedite a HS3 conversion. Might be worth the cost if HS wont turn it over to us.
HS: 3.x
HW: Insteon PLM 2412U, RFXCom, Concord Ultra w/AM, Brultech GEM, Brultech Dashbox, ELK-930, Venstar tStat T7900
3P-Plugins: GE Concord HS3, MS_Insteon HS3, UltraCID HS3, RFXCOM HS3, Venstar tStat HS3
3P-Plugins Admin: GE Concord HS3, Venstar tStat HS3 (beta)
Scripts: n/a
Server: Win8 (64bit), Intel i5-4670 3.4Ghz, Asus Z87i MB, 16GB RAM, 256GB SSD/1TB SATA
Old February 12th, 2016, 12:16 AM
Seer Deluxe
-Matt
I have Aprilaire plugin working with HS2. This is the only missing plugin before I can upgrade to HS3.
Old February 13th, 2016, 10:45 PM
Seer Deluxe
Ok. I actually went for the Venstar thermostat and signed up to do that plugin for HS3. If that doesnt work well I may swap to an Aprilair.
Matt
Old June 17th, 2016, 01:19 PM
monument monument is offline
Seer
hi all. new guy here-- i bought a home that has HS2 running a plugin talking to 10 Aprilaire stats -- only 5 furnaces, but used for floor heat zones and humidistats too -- works ok but trying to move to HS3 for other things. Would love an Aprilaire HS3 plugin so wanted to register my interest as well.
Just started running HS3 in parallel and am porting systems one by one, so ready to help with testing if needed.
Old June 26th, 2016, 02:52 PM
smacarth smacarth is offline
Seer
Source Code
Awhile back I inquired about the Aprilaire HS2 source code. HomeSeer provided me a link to the source code for purchase. I recently retired and might be interested in purchase and see what it would take to upgrade the HS2 to HS3. Not sure why no one has attempted this yet since there does seem to be a fair amount of interest in the Aprilaire plugin for HS3.
Old June 27th, 2016, 06:41 PM
Seer Deluxe
Quote:
I'd buy it if there is a HS3 plugin for Aprilaire. It's the only thing preventing me going to HS3
  #16
Old March 7th, 2017, 11:08 PM
Near76 Near76 is offline
Viewer
Aprilaire with HS3...?
Any updates? I'm in the same boat, I have a two zone Aprilaire system running HS2 and want to upgrade to HS3 without tearing it out. I use the remote temp sensor of the Aprilaire and don't see that feature in others out there. I'm willing to help financially as well.
  #17
Old March 21st, 2017, 12:17 PM
macromark's Avatar
macromark macromark is offline
HomeSeer Technologies
If anyone wants to build a plug-in for Aprilaire, email me directly (mark at homeseer dot com) and I'll put you in touch with the right person at Aprilaire. He will provide you with the API and also with the hardware you need to create the plug-in.
  #18
Old June 16th, 2017, 01:23 AM
Seer Deluxe
Quote:
Mark, did anyone take you up on this?
  #19
Old October 31st, 2017, 10:36 AM
lizard32 lizard32 is offline
Viewer
Did anyone ever get this working in HS3? Glad I ran across this. I was about to go all in on HS but without support for this its a showstopper.
HTML code is Off
HS-Elk-Aprilaire 8870 will40 UltraM1G HSPI 3 August 17th, 2008 05:05 AM
Aprilaire setup with Elk M1G ctwilliams Aprilaire 1 August 27th, 2007 07:41 PM
AprilAire GreenAcres HS2 / HSPRO 11 May 18th, 2007 09:41 AM
Aprilaire 8870 cutthroat Aprilaire 0 November 11th, 2006 11:04 PM
Aprilaire 8870 keng Script & Plug-In Library Discussion 1 January 11th, 2004 03:51 PM
