Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HS3 / HS3PRO > HS3 Virtual Devices
HS3 Virtual Devices Discussions related to the creation of HS3 Virtual Devices and Related Events
Old April 21st, 2017, 07:48 AM
tccug221 tccug221 is offline
Seer
Virtual device Value set with GET
I have a raspberry pi with some sensors on it. The Sensors will return data with a web GET. For example, if you request http://10.10.10.10:1200 a value from one of the sensors is returned. Is there a way to get this value and assign it to a virtual device?
Old April 21st, 2017, 10:42 AM
mrhappy mrhappy is offline
OverSeer
Yes although it will depend on what the data is returned by, is it plain html, text, XML, JSON etc. If it is very simple text you might be able to get by with a single line scripting call, if not then it's likely to need a full script (which would be a couple of lines) you would run in a recurring event.
Probably best if you post the contents of the web page so it can be understand how it is coming back to you.
Old April 21st, 2017, 11:11 AM
Seer
Yes, its a simple value, for example, a temperature or humidity value. 67 or 100 say. What would be the single line script?
Old April 21st, 2017, 11:17 AM
epimetheus epimetheus is offline
Seer Plus
You could also go about it another way. Have the pi control the HS virtual device via a JSON call. I'm using Node-Red on a pi3 to send various sensor data to HS3 with this method.
Old April 21st, 2017, 11:22 AM
Seer
So you are using some sort of timer and sending data to HS at intervals?
Old April 21st, 2017, 06:51 PM
Seer Plus
Node Red allows you to set interval triggers to perform actions. I'm also using it to parse http info from my CAO Gadgets Wireless Tag Manager (Tag Manager > RPI3 w/Node Red > HS3).
Sent from my Pixel XL using Tapatalk
Tags
virtual device
HTML code is Off
Store and retrieve device status (in virtual device?) Patholoraptor BLDenon (3P) 1 August 9th, 2016 09:25 PM
Can a virtual Harmony Hub device control a real device or activity in HS? rayvino Harmony Hub 15 April 13th, 2016 07:53 AM
How to combine device status's into virtual device bandook HS3 Scripting 7 February 12th, 2016 02:41 PM
HS3 Script Syntax to copy one virtual device status string to another virtual device pjohnson HS3 Scripting 8 December 31st, 2014 02:48 PM
Parse device string and update as the value of a virtual device ccat HomeSeer General Discussion Area 5 December 14th, 2010 04:32 PM
