Go Back   HomeSeer Message Board > Legacy Software & Plug-ins > Legacy Software (Older Versions) > HS2 / HSPRO > HomeSeer Phone
HomeSeer Phone This area is for discussions that are very specific to HomeSeer Phone including IVR script discussions and script postings.
Old December 10th, 2008, 05:40 PM
Wadenut's Avatar
Wadenut Wadenut is offline
W2C Suddenly stopped working
After a reboot, I'm getting this on startup.
And naturally, my phones are dead unless I unplug the W2C modem.
I've just finished reinstalling the W2C driver, same result.
Also tried reinstalling HS 2.3.0.9
DESPERATE!
12/10/2008 5:16:34 PM - Error - Initializing audio play/record support: Unable to cast COM object of type 'hsrecord2.hsrecordplayClass' to interface type 'hsrecord2._hsrecordplay'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{C9B8687D-F497-4520-98A0-ED20C8634473}' failed due to the following error: Error loading type library/DLL. (Exception from HRESULT: 0x80029C4A (TYPE_E_CANTLOADLIBRARY)).
12/10/2008 5:16:34 PM - HSPhone - Error initializing Hi-Phone driver, possible corrupt or missing drivers, or Hi-Phone is not plugged in or powered on.
Old December 10th, 2008, 05:47 PM
completelyhis completelyhis is offline
does the way2call test out ok with the hiphone icon app? did you look at the way2call website to get the most current drivers? search through the board, bill brower did an excellent write up years ago on how to uninstall and reinstall the drivers. it is VERY particular in what order certain things are done.
Old December 10th, 2008, 05:57 PM
Rupp's Avatar
Rupp Rupp is offline
Did you try rebooting again to see if this object registers?
-Rupp
Alconnell's Avatar
Alconnell Alconnell is offline
Strange error - definitely try the de/re process as outlined by Bill. Is the power light on the W2C? And have you tried reconfiguring the modem in the HS/Setup/Phone?
Old December 10th, 2008, 06:03 PM
Wadenut's Avatar
In order I think...
The W2C diagnostics passed.
Did reboot several times.
Haven't found Bill's dialog.
Power light is on.
Trying a backup of HS.
Can my day get any worse??
Old December 10th, 2008, 06:20 PM
Wadenut's Avatar
Everything checks, except that the phones go dead after this error from HS. It's as if HS is half initializing then leaving the modem in some unknown state.
Backup restore didn't help.
Last incoming call was about 2 hrs before I restarted HS.
Old December 10th, 2008, 07:10 PM
Alconnell's Avatar
Here's the thread from Bill:
http://board.homeseer.com/showthread...ay2call+driver
You didn't mention if you tried reinstalling the modem under Setup.
Old December 10th, 2008, 07:14 PM
Wadenut's Avatar
I'm OK.
I ended up uninstalling HS using the installer. Then, Reinstalled the full verison of 2.3.0.0 and 2.3.0.9 on top. Started and had of course lost my config and plugins etc. Uninstalled again, reinstalled as before but this time, restored my backup to the directory. Restarted and Voila!
Let this stand as a warning however to us all. Let's hope it's an isolated incident but this happened, for no ascertainable reason after a simple and routine restart of HS. Had I not noticed the error on startup, my phones could have been dead for some time.
I had already logged a Help Desk ticket and I'll add this info to it.
Old December 10th, 2008, 07:24 PM
Wadenut's Avatar
Thanks for looking that up for me Alconnell. However, I'm nearly certain it was HS that had failed here. In this case, the HiPhone diagnostics worked. It was only HS that had the problem.
My day was downhill from the start. Thank the Lord it's almost over.
Old December 10th, 2008, 10:23 PM
rmasonjr's Avatar
rmasonjr rmasonjr is offline
Wadenut
Now that the dust has settled and you are back online...
I noticed above that all of your phones were down. Are you running your main line into your Way2Call then to all the extensions in your house? I've thought about doing this with the HS PCI Modem so I can grab outgoing calls from any phone in the house.
Can you elaborate on your setup?
Rob
Old December 10th, 2008, 10:36 PM
Rupp's Avatar
See this thread for info on how to wire your modem.
http://board.homeseer.com/showpost.p...22&postcount=6
Old December 10th, 2008, 11:15 PM
rmasonjr's Avatar
Aw man - that is gold - thanks!!!
Old December 11th, 2008, 05:20 AM
Wadenut's Avatar
I have one cordless base plugged into the modem, with four cordless extentions. That way all of my phones are "controlled".
Old February 7th, 2009, 03:50 PM
CJVann's Avatar
CJVann CJVann is offline
I have the same problem and the W2C passes all tests and was working fine until I booted up (I just happened to use the phone prior to rebooting). I've tried numerous backups of HomeSeer, and they all do the same thing now - no phone service to the house unless I unplug and re-plug power to the W2C after HomeSeer boots.
2/7/2009 2:41:19 PM Error Initializing audio play/record support: Unable to cast COM object of type 'hsrecord2.hsrecordplayClass' to interface type 'hsrecord2._hsrecordplay'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{C9B8687D-F497-4520-98A0-ED20C8634473}' failed due to the following error: Error loading type library/DLL. (Exception from HRESULT: 0x80029C4A (TYPE_E_CANTLOADLIBRARY)).
2/7/2009 2:41:19 PM HSPhone Error initializing Hi-Phone driver, possible corrupt or missing drivers, or Hi-Phone is not plugged in or powered on.
Old February 7th, 2009, 04:20 PM
Bill Brower's Avatar
Bill Brower Bill Brower is offline
CJ: The first step I'd try is shut down HS2 and do a reinstall or fix from Control Panel / Add or Remove Programs. Then reboot.
~Bill
Old February 8th, 2009, 04:01 AM
CJVann's Avatar
Hi Bill - I had another issue as well, and tried the repair and it wiped out everything I had. I don't know if I was supposed to rename the Sample.mdb to something else to prevent this from happening or what went (horribly, horribly -lol) wrong, but at any rate, I had to start over with a fresh install of HS and it's working fine now. Thank you for your help!
CJ
Old February 8th, 2009, 11:42 AM
There may be other sampleX.mdb files in your config directory.
You could try a search. But then fresh starts are good too.
Old February 8th, 2009, 12:36 PM
CJVann's Avatar
I just checked - nothing but sample.mdb. It's okay - I have an ISY now, so 75% of what used to be controlled by HS is controlled by the ISY, so it wasn't too painful to recreate. HS does X10RF, media player, HS Phone and announcements. All the lighting & many events are done by the ISY, which saved a huge amount of time re-entering devices! But - you just reminded me to save my database under another name... DONE! Thanks!
Old February 10th, 2009, 03:19 PM
The Ol Alfer's Avatar
The Ol Alfer The Ol Alfer is offline
Phone Jack
Hello Rupp:
Just looked at this thread and see where this referral is to the wiring of the phone lines through a line splitter.
I was wondering why more people do not use the RJ31X Phone jack. This is what I use as this jack is for connecting alarm panels so they have exclusive control over the phone line. (e.g. leaving a phone off hook will not stop the panel from dialing out an alarm)
The other great benefit of using this jack is that if you have a problem with HS, or the modem and the phones are not working as is the content of this thread, you can just unplug the line from the RJ31X jack and all of your phone are reconnected to the Telco line, just as they were before you started into home automation phone control.
Here is a web page that does a great job explaining how this jack works and how to wire it to a panel, in our case with a HS modem we would connect the RED GREEN wires to Line IN on the modem and the YELLOW BLACK to the line OUT on the modem.
http://www.systemswebstore.com/faqfi...connection.htm
Trouble with your phones unplug the jack, there all back to normal till problem is fixed.
Hope this helps some one ,,,
--- Ol ALfer ---
"I Love My Country, But Fear My Government !!!"
