Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion
Lighting & Primary Technology Discussion Lighting & Primary Technology General Discussion
Old March 20th, 2011, 08:46 AM
Richel Richel is online now
X10 interference from Z-wave lamp devices
I have a multitude of X10 products in my house and I am adding Z-wave products. I have found that some of my Z-wave lamp modules are creating havoc with X10 signalling, such that I have had to interpose a filter (XPPF) between the Z-wave device and the electrical outlet. I was wondering if anyone else has had this problem.
Old March 20th, 2011, 10:46 AM
Rupp's Avatar
Rupp Rupp is offline
I've only seen one other report of this mentioned. What level of noise is being reported by your signal meter?
-Rupp
Old March 20th, 2011, 11:12 AM
Sorry, but I don't have a signal meter.
Old March 20th, 2011, 06:36 PM
kaldoon's Avatar
kaldoon kaldoon is offline
What Z-Wave Lamp modules seem to be causing the problem?
Old March 21st, 2011, 10:39 AM
BobT's Avatar
BobT BobT is offline
In addition to which Z-Wave module(s) make & model, does the offending module cause this problem when it is dimmed and/or at full power?
Do other module(s) of the same make & model also cause the same problem?
Old March 21st, 2011, 01:16 PM
TeleFragger's Avatar
TeleFragger TeleFragger is offline
^^ as BobT asked that would be helpfull too...
i too am on a slew of x10 and will not go away from it... i have a box of about 75 z-wave modules to go in... and just havent bothered yet....
all of mine are the intermatic ones... lamp, appliance, outlets
Old March 22nd, 2011, 07:19 AM
lhfarm lhfarm is offline
Signal sucker, not noise
Here is what I found -
http://board.homeseer.com/showthread.php?t=147418
Barry
Tags
x10, z-wave
