Can you try 1.0.28 and see if you can cause it again
DOT Files
Hi Bob,
Is there a reason why there's a minimum size of 10 pixels width in the DOT Editor? I want to create a few that are smaller (5-7 pixels) and see that your music note is 9 pixels wide, but in the editor drop down, 10 is the smallest width you can select.
AlHS 4.2.8.0: 2134 Devices 1252 Events
I have tried displaying a DOT image produced by the plugin by adding in the proper lines to a VB.net script.
Does someone have a sample VB.net script and some configuration and event screen shots they would share so I can get my image(s) to display.
If there were a plug-in option to do it from the event page without resorting to scripting, it would be so much better.
What I'm trying to do is get some animation by building DOT files that grow in pixel sizes to make things move. Is there a better way to animate stuff?
Trying to get a 'runner' to look like they are running across the betabrite.huggy_d1
Automating made easy
Hi huggy,
This is what I use for code:
Code:Dim curSequence As String = hs.PluginFunction("BLLED", "", "GetSequence", new Object(){1}) Dim DOTPath = hs.GetAppPAth & "\Data\BLLED\DOT\" 'path to DOT files DOT = DOTPath & "Test.bmp" hs.PluginFunction("BLLED", "", "SetPicture", New Object(){1, "A", DOT}) 'set picture in DOT id A If InStr(curSequence,"D") = 0 Then hs.PluginFunction("BLLED", "", "SetSequence", new Object(){1,curSequence & "D"})
Cheers
Sparkman,
I tried what you posted but apparently I did something wrong. I either lock up my 8K BetaBrite, or it skips over that message, or displays a blank message when the dot image should be visible.
I contacted Blade for some help and he made a new version that helps with event driven image display. However, even that did not work for me - yet at least.
I must be missing something in the BB configuration that keeps the message from displaying the DOT file.huggy_d1
What I found is that I need to manually add the picture first using the BLLED plugin pages and then restarting the sign so that the memory gets allocated properly first. If I set messages, strings or DOTs using a script initially, then I have the same issue. If I set them using the web-pages first and then modify them using scripts, then it works fine. Hope that works for you.
Cheers
