Com Port status device
    i have had an issue recently with my comport disconnecting, and as a result the caddx plugin stops working.
    i was wondering if we could get a device that gives the status of the comport so i can have homeseer send me an email if it goes offline.
    thanks
    Raptor
    HS3 Pro on Windows 8 64bit
    53 Z-wave nodes(46 devices, 7 remotes), 15 DS10a's, 10 ms16a's, 9 Oregon Sensors, W800, RFXCOMtrx433, Way2Call, 3 HSTouch Clients, 2xRussound CAS44, Global Cache GC100-12,10 Rollertrol blinds(+ zwave) ,3 Squeezebox Radios and 1 Squeezebox Boom,DMX Arduino via ethernet,Rain8Net,3x Echo Dot's
    Check out my electronics blog here:
    https://www.facebook.com/RaptorsIrrationalInventions
    I am also looking for a slimier request or a away to auto reconnect instead of manually opening the setup and pressing connect.
    I tried an event but there is no trigger or action that can be done with this.
      any thoughts Rien?
        Not easy, let me see what I can do
        Rien du Pre
        The Netherlands
        Using:
        Plugin's:
        RFXCOM, mcsMQTT, Z-Wave
          thanks, your work is appreciated.
