Hello-
I am having trouble setting ramp timers via parameter. I ran across a thread today that Rich had posted in regarding setting ramp rate parameters via event here. Here is an excerpt:
I set up an event to change parameter 8 (remote timer) and it did nothing. I went into the z-wave tab for the dimmer and tried setting parameters 8 and 10 manually... after hitting set, the actual timer value stayed the same, and the previous value replaced my requested value in the Set Configuration Parameters value window. In the image below, I tried to set parameter 10 to 5, but after hitting the Set button, the value reverted to the current setting.
If I tried to set parameter 7 or 9 (steps), it worked as I would expect. But 8 and 10 (timers) are a no-go. Any ideas?
Jon
local control dim rate (dimmer only)
9 = step (1-99)
10 = timer (1-255)
remote control dim rate (dimmer only)
7 = step (1-99)
8 = timer (1-255)
9 = step (1-99)
10 = timer (1-255)
7 = step (1-99)
8 = timer (1-255)
Jon
