Honeywell Lyric Plugin - Beta Release History
    A Beta version of the Honeywell Lyric Plugin is now available from the HomeSeer updater. This forum will serve as the primary support and communication channel.
    *** Initial Beta Release Version 0.9.2 *** - 11/25/2017
    *** Version 0.9.3 *** - 12/8/2017
    • Added check for supported Mono Version.
      *** Version 0.9.4 *** - 12/16/2017
      • Fixed an issue where Thermostat data failed to parse when used with a device that doesn't support schedules or placing holds.
        *** Version 0.9.5 *** - 12/30/2017
        • Fixed an issue where Thermostat data failed to parse when used with a device that doesn’t support fan controls.
        • Extended trial date to 1/31/2018.
          *** Version 0.9.6 *** - 1/1/2018
          • Fixed an error caused by debug code left in the last release. Oops!
            *** Version 0.9.7 *** - 1/4/2018
            • Fixed an issue with the Download Log File button.
            • Added additional TRACE logging.
              *** Version 0.9.8 *** - 2/1/2018
              • Fixed an issue where thermostat devices failed to be created on devices that don’t have scheduling capabilities.
              • Extended trial date to 2/28/2018.
