UltraFlowMeter3 - Startup Error
    I just installed the UltraFlowMeter3 plug-in version 3.0.6542.19763. When I restart Homeseer, the startup log says:
    1/15/2018 8:11:50 PM ~!~Plug-In~!~Found plug-in: UltraFlowMeter3, version: 3.0.6542.19763
    1/15/2018 8:11:59 PM ~!~Plug-In~!~Interface UltraFlowMeter3 is running as a trial, 30 days remaining.
    1/15/2018 8:11:59 PM ~!~Error~!~Starting plug-in exe process: The specified executable is not a valid application for this OS platform.
    When I go to Homeseer Plug-ins->Manage, the plug-in status for UltraFlowMeter3 says:
    "WARNING: Failed getting InterfaceStatus from UltraFlowMeter3 - the interface was not found in the list of active interfaces, the list may need to be refreshed."
    I am using Homeseer version 3.0.0.368, on Windows XP Embedded on a Hometroller.
    UltraFlowMeter3 supports Windows XP, right?
    I am not doing any OS checks within my plug-in. It should run on any system that can run the latest version of HomeSeer3. I quick google search seems to imply the error is related to a .NET Framework check. Please open a case with HomeSeer Tech to help decipher what that means.
    Regards,
    Ultrajones
      Regards,
      Ultrajones
      I read something online about program should be built with option to target .NET Framework 4 to support XP.
      Looks like I have .NET Framework 4 (this came as part of the SSD image that came with HomeSeer's upgrade package to upgrade my HomeTroller from S3 to S4). Attached is a screen shot from Control Panel indicating the .NET software installed in my system.
      I submitted a tech support request to HomeSeer describing this problem as well.
          I use the same method to compile all 20 of the plug-ins I published to the HomeSeer store.
          Are you attempting to run my plug-in on a HomeTroller S6?
          Regards,
          Ultrajones
