Q. What weather providers does weatherXML use?
A. You can select from the following.
Weather Underground, NOAA weather (US Only), World Weather Online and Norway Yr.No. In addition for Australian users there is a custom feed available. For users of the Cumulus software, weatherXML will import from the realtime.txt file. Just enter the directory where the realtime.txt file is and weatherXML will watch for it to be updated.
If you prefer you can select one provider for the current conditions and a different provider for the forecast information.
Some information is only available from certain providers. For example the Hourly 10 day forecast and history values are only available by using Weather Underground.
Q. How many locations can I setup?
A. As many as you want. Initially, you can have up to 10 but if you actually want more than 10 the value can be user changed to allow as many as you want.
Q. I am getting this error trying to install the plugin on a Linux install - Updater Error downloading file: Error: SendFailure (Error writing headers)
A. Check out this thread for how to fix the error. http://board.homeseer.com/showthread.php?t=169800
