Hi Jeff,
I have had this issue a few times but thought it was a fluke. Since it happened again today and I caught it, I thought I would report it.
I have the daily forecast updating at 0400 each day. Today it downloaded the file (attached) and seemed to process it. I see no errors in the log.
At 0700 I have a 2 day forecast speak. Today it did not insert the forecast. I attached a screen shot of the last speak. You can see it just said the hard coded words or the variable names I have in the speak but not the actual forecast.
I thought it might be an issue with the download but the file seems to have everything it needs.
Let me know what you need from me to help track it down. Using version .79
Dec-06 04:01:01 weatherXML Alerts Finished
Dec-06 04:01:01 weatherXML Checking alerts for Banks St
Dec-06 04:01:01 weatherXML Check for alert triggers
Dec-06 04:01:01 weatherXML Check devices
Dec-06 04:01:01 weatherXML Check for expired alerts
Dec-06 04:01:01 weatherXML Alerts: No alerts currently.
Dec-06 04:01:01 weatherXML Set the number of alerts: 0
Dec-06 04:01:01 weatherXML Unknown Alerts to check: 0
Dec-06 04:01:01 weatherXML Minor Alerts to check: 0
Dec-06 04:01:01 weatherXML Moderate Alerts to check: 0
Dec-06 04:01:01 weatherXML Severe Alerts to check: 0
Dec-06 04:01:01 weatherXML Extreme Alerts to check: 0
Dec-06 04:01:01 weatherXML The file C:\Program Files (x86)\HomeSeer HS3\Data\weatherXML\NOAlerts1.xml is ready for import.
Dec-06 04:01:01 weatherXML Start Import:
Dec-06 04:01:01 weatherXML The file C:\Program Files (x86)\HomeSeer HS3\Data\weatherXML\alerttemp1.xml is ready for import.
Dec-06 04:01:01 weatherXML Staus: Success
Dec-06 04:01:00 weatherXML Replacement URL: http://alerts.weather.gov/cap/wwaatm...p?x=TXZ213&y=1
Dec-06 04:01:00 weatherXML The file C:\Program Files (x86)\HomeSeer HS3\Data\weatherXML\NOAlerts1.xml is ready for import.
Dec-06 04:01:00 weatherXML Running Alert for location 1
Dec-06 04:00:45 weatherXML Done reseting the ini values
Dec-06 04:00:45 weatherXML Date: Dec/12/2017
Dec-06 04:00:44 weatherXML Date: Dec/11/2017
Dec-06 04:00:44 weatherXML Date: Dec/10/2017
Dec-06 04:00:44 weatherXML Date: Dec/09/2017
Dec-06 04:00:44 weatherXML Date: Dec/08/2017
Dec-06 04:00:44 weatherXML Date: Dec/07/2017
Dec-06 04:00:44 weatherXML Date: Dec/06/2017
Dec-06 04:00:38 weatherXML The file C:\Program Files (x86)\HomeSeer HS3\Data\weatherXML\WUForecast1.xml is ready for import.
Dec-06 04:00:38 weatherXML Check Graphic Forecast Vertical Device
Dec-06 04:00:38 weatherXML Check Graphic Forecast Horizontal Device
Dec-06 04:00:38 weatherXML Check for refID: -1
Dec-06 04:00:14 weatherXML Check for refID: 385
Dec-06 04:00:13 weatherXML Set devices for HSTouch usage
Dec-06 04:00:13 weatherXML Set Forecast Device
Dec-06 04:00:13 weatherXML Checking 12/12/2017 12:00:00 AM
Dec-06 04:00:13 weatherXML Checking 12/11/2017 12:00:00 AM
Dec-06 04:00:13 weatherXML Checking 12/10/2017 12:00:00 AM
Dec-06 04:00:13 weatherXML Checking 12/9/2017 12:00:00 AM
Dec-06 04:00:13 weatherXML Checking 12/8/2017 12:00:00 AM
Dec-06 04:00:13 weatherXML Checking 12/7/2017 12:00:00 AM
Dec-06 04:00:13 weatherXML Checking 12/6/2017 12:00:00 AM
Dec-06 04:00:13 weatherXML Data imported for Weather Underground. Finish the process
Dec-06 04:00:13 weatherXML ImportWUForecast Date: Dec/12/2017
Dec-06 04:00:13 weatherXML ImportWUForecast Date: Dec/11/2017
Dec-06 04:00:13 weatherXML ImportWUForecast Date: Dec/10/2017
Dec-06 04:00:13 weatherXML ImportWUForecast Date: Dec/09/2017
Dec-06 04:00:13 weatherXML ImportWUForecast Date: Dec/08/2017
Dec-06 04:00:13 weatherXML ImportWUForecast Date: Dec/07/2017
Dec-06 04:00:13 weatherXML ImportWUForecast Date: Dec/06/2017
Dec-06 04:00:13 weatherXML Set forecast information
Dec-06 04:00:00 weatherXML Replacement URL: http://api.wunderground.com/api/API/...N/q/30,-95.xml
Dec-06 04:00:00 weatherXML Download WU Forecast: 9
Dec-06 04:00:00 weatherXML Data from Lat/Long
Dec-06 04:00:00 weatherXML Forecast Source: wu
Dec-06 04:00:00 weatherXML Running Forecast
Michael
Michael
