Every 6 mos or so I realize the Weather XML plugin isn't working. The wife always points it out though. Apparently this time it stopped on the 12/16. I look at it, and just assume it's correct. I need to include some type of error checking that if the data is over 2 days old, an E or something is displayed. I use Devices by the way. Maybe I need to move to rss feeds? But anyways, back to the issue at hand, how do I fix it? I've restarted HS, I've just restarted and reinstalled WeatherXML, and neither actions corrected the issue. The last time I had this occur, I reinstalled XML, and the setting box was the only entry available, and I edited my location to somewhere else, and changed it back to my location, and some kind of download happened, and it was off running again. This time i'm not seeing anything like that. In the Homeseer Data files, under WeatherXML, I see a few files with last update was on the 16th, and a couple of other files that haven't been updated since october, and august, screenshot attached. I assume I need to delete something.
Also, if I go into settings>Locations, I get this error message: "Locations Settings Error: Index was outside the bounds of the array."
I saw a different thread on that error, and I enabled debugging and get this error on the locations tab: I also went into the Config directory, and the WeatherInfo ini file is blank. I guess I need to delete that and let the backup do it's thing. I guess, but I'll wait on taking action on that lol. I mean, it that guess hasn't even graduated to an assumption yet.
Dec-29 11:12:10 PM weatherXML page: weatherXML_loc, data: &id=menuTopLocations&menuTopLocations=Submit
Dec-29 11:12:06 PM weatherXML page: weatherXML_loc, data: &id=menuTopLocations&menuTopLocations=Submit
