I remembered reading about this controller and the fact it won't address nodes above the number 32. I remembered it, and then promptly forgot. I bought one and have it in the kitchen happily controlling a bunch of lights. I have pseudo-scenes programmed even.
Then I added more devices to my network.
Then I deleted some, and added more. Then SWMBO wanted a switch for all the Christmas lights.... some of which are on plugs with node numbers bigger than 32. D@mn!
I like these cause they are wireless and stick-on. I don't have a spot to mount one in a gang box, unless I remove a switch... which is a possibility I guess depending on how they wire up.
So, is there a similar product out there, wireless, sticky-tape mountable, that addresses more nodes? Barring that, any suggestions on how to make the 45631 work? Can I reassign node numbers? Or, am I rebuilding the system, adding what I want controlled by these keypads first.... d@mn!
Cheers!
Chris
Cheers!
Chris
