Well, the door contacts did this:
Read the links and it came back empty, programmed for HS and they are good to go. No option as you would expect since they are a simple device
motion sensors: before I was unable to set parameters from HS. Put in jumper 5 for software control and read links, came back empty, programmed for HS. Now I'm able to configure them via your plugin
Perhaps you know what Op Flag Occupancy mode = enabled/disabled. Not finding this in the documentation anywhere. If not, that's OK I'll keep looking
I did find that some devices were needing reprogramming while others didn't seem to be affected. I assume this is due to some of them were still using i2 rather than i2sc.
Anyway, my life became a little easier tonight
Off topic:
FYI, I bought some ZWave stuff to play with to see what mix would be the best. Man the ZWave stuff looks and feels cheap and poorly designed! The door contact is huge, the switches look like their meant to be in a thrift store. I kinda regret even trying them, but I like playing so it's all good. Some things they have Insteon doesn't, so I'm sure I'll have a mix.
Off topic again:
Saw in your Siggy that you use an HAI TStat. Like it? Not sure if you know, but they got bought out by Levington and they say they're putting in a bunch of dev $$. that's really good news for the product as it really needs an update. I've installed a few homes with this stuff and I wasn't very impressed, especially with the UPB network. Scene lighting was VERY choppy and serial rather than being treated like a group command (like Insteon does). Homeowners were a little grumpy, but they chose the system, I just did the instal (thank god, cause I'd feel pretty bad if they weren't happy with my choice!)
Anyways, have a good night and, again, I appreciate the help you gave me!
Off topic:
Off topic again:
