Oman -
I'm still a bit confused about where this stands. I think you posted a 'fixed' version of the plug-in that somehow worked around or corrected the lack of proper ACK from the SA PIM? What exactly does this mean?
* When the plug-in is talking to the SA PIM, does the SA PIM confirm back to it that the controlled device received and executed the command?
* Or, are you just assuming that the command got executed?
* Or, are you recommending that we set the plug-in to 'retransmit' the command several times to increase the probability of success?
* If I do set the 'retransmit' parameter in the plug-in to more than 1, does this increase traffic on my power lines, and/or is it possible that the command gets executed twice?
* Does the PIM itself, independent of your plug-in, monitor the power line for a confirmation of command execution from the devices and resend if none is forthcoming?
My goal: determine if I should swap out the SA PIM that I have for a PCS PIM (I have to send some other stuff back to the retailer today, so I can include this item as well.)
Jerry
Jerry
