I bought a new SA PIM and it seems to be working ok. The only concern I have is that the UPBStart software identifies it as firmware 4.15 and the posts on I see suggest that I should be at firmware 4.2x. Any thoughts on the subject? Should I try to return it?
Sa Pim 4.15
UPBseer
Current Firmware ?
There is a thread where a couple of experts talk about version 4.2. The thread
http://board.homeseer.com/showthread.php?t=107699
has the following post which clearly talks about a 4.2 version of the firmware.
So where am I confused?
The SA PIM that you have is the same version as the SA PIM that I use and it properly generates the ACK/NACK bit. I would not return it based solely on this criteria.
I'm not tracking versions of the UPB Plugin, but I believe that the initial release ignored the ACK/NACK because the SA PIM 4.2.x did not process it correctly. I never knew that a problem existed with the 4.2.x firmware so xapmcsUPB does process it and gives up to three retries if either the ACK is not received or a NACK is received.James
Running HS 3 on Win10 .
UPBseer
Current Firmware
Could it be that they are not referring to the PIM (CIM) firmware? The current version for PCS and SA interface module is 4.15.
