Insteon Basic Plug-in Quick start (PLC Version of the plug-in):
1) Download the Insteon plug-in beta from the updater.
2) Follow the prompts/log entries displayed to install the new SmartHome Device Manager (SDM)
3) Start HomeSeer
4) Click the Setup button in the web interface. Select the Interfaces tab.
5) Click on the "Disabled" button in the Insteon row under X10 if you want X10 support. Click on the "Disabled" button in the Insteon row for Insteon support.
6) Click on the Save button at the bottom of the page.
7) Click on the Insteon Configuration button at the top of the page.
8) If you see a warning about a problem finding the SDM or your Insteon controller you need to fix the problem before going to step 9
9) Press the Completely Reset PLC button to configure the PLC for use with HomeSeer. Wait for it to complete.
10) Click on the Manage Devices button
11) Click the Tap-Add Insteon Devices button
12) Go to each device you want to add and tap-link it to the plug-in (see the documentation for the device, usually hold the button or switch for 3 or ten seconds)
13) For each device you add you should see a listing on the plug-in screen.
14) When done select the Done Tap-Adding devices button
15) Select the Edit Device # button for each device you added and give it a more descriptive name and location.
16) Click the Save Changes button
17) Now select the Program Device button to program the device for use with HomeSeer.
Repeat (go to step 12) for each device
For details see the PDF file that ships with the plug-in.
Jon
3) Start HomeSeer
Jon
