Originally posted by JonCluts
View Post
Insteon PLM Plug-In Version 1.5.2 (license required)
Mark
HS3 Pro 4.2.19.5
Log Files
Originally posted by mnsandler View PostI think you will be able to post attachments after a few more posts. i think either forum user Rupp or Macro Mark can change your profile. maybe a post to their visitor page will help
Originally posted by mnsandler View PostCarlo,
Another user mentioned to me that you need to use the 'Tap-Add' feature to register the device. Adding it manually will not work as we have found out.
so put the device into linking mode and then click the 'tap-add new insteon devices' btn from the plugin Manage Devices page.
Mark
Thanks for the info! That worked and I now can control it through the status page.
Carlo
Carlo
let me know if you have any problems with the device so we can work them out for the next userMark
HS3 Pro 4.2.19.5
MorningLinc Problems - Error Log
Originally posted by mnsandler View PostJonathan,
I need to see the log related to the registration process
can you post the part of the log that show where you registered the device with the plugin. If you don't have it or you didn't have detailed debugging turned on, would you mind deleting it and reregistering with detailed debugging on.
also, i need to see your ini with the section for the device
Ok got my posting permissions figured out (thanks Rupp!) and have tried to get you what you need. Here are the steps I took:- Turned on detailed debugging on.
- Removed the MorningLinc
- Added the MorningLinc Back, by entering the ID. I did not tap add it.
- Checked that it worked from the Status page. It controlled the lock correctly.
- Added a device command to an Event to lock the deadbolt. When I test the event the event fails and posts the following to the Homeseer log:
Hope this helps and again thanks for your work on this plug in.Last edited by JonCluts; January 15, 2011, 01:16 PM.
Turns out your need to tap-add the morninglinc. Have you tried thisMark
HS3 Pro 4.2.19.5
MorningLinc
Originally posted by mnsandler View PostTurns out your need to tap-add the morninglinc. Have you tried this
After that it is always recognized by just adding in the ID.
Tonight,after reading your suggestion, I tried several times to delete it an add it back by tap-adding, but it always fails (it discovers the MorningLinc device but says it can't read the links). In this mode it does not work from the status page any longer.
Let me know what other information I can provide.
Jonathan
Jonathan, please try this build and report back.
added: You may need to readd the device in order to get the status page btns to work againAttached FilesMark
HS3 Pro 4.2.19.5
Morninglinc
Mark,
I was able to try out the new version you posted and was able to add the MorningLinc device and it correctly read its settings. I am able to control the device from the status page, but still am not able to add a device control event in an event. When the event is run I see this error in the log:
1/12/2011 6:29:19 PM - Insteon - ** An error occurred in this plug-in. The details have been written to the log file - C:\Program Files\HomeSeer\Config\Insteon Error Report.Log
I have attached the latest log here as well.
Thanks again for all your support.Last edited by JonCluts; January 15, 2011, 01:18 PM.
Thanks again for all your support.Mark
HS3 Pro 4.2.19.5
I don't have a morninglinc to try so this may be a little slow with all the back and forth.Attached FilesMark
HS3 Pro 4.2.19.5
Originally posted by joegr View PostHere's another data point for you. My Morninglinc works, but I am unable to read or modify links in it.
if you aren't runing 1.5.2.13 or later, please upgrade to the build (1.5.2.19) posted above. I made a change regarding the link database on the ML which i think fixed that problem.
can you try an event action that turns the ML on or off and post your results
i guess i need to bug SH to send me a ML; i'll see what i can do.Mark
HS3 Pro 4.2.19.5
Originally posted by joegr View PostI'll try it tonight. (Events are working for me now. I'm at 1.5.2.0)
i'll post a fix later tonight for all to tryMark
HS3 Pro 4.2.19.5
