It must be me, because also by selecting 0, it still shows 0 in the battery field for all 4 sensors.
Insteon PLM Plug-In Version 1.5.6 Beta (license required)
An observation...
All of my insteon motions are v1.0 With this build I went to one of the motions and, mainly because I was curious, set the LED brightness to 30%. The log shows successfully programming. But after that the motion would not trip. So I went back in to the programming and found that the change had also changed the sensitivity to the same value. I changed the sensitivity back to it's default and all was good again.
CMHomeSeer Version: HS3 Pro Edition
Operating System: Microsoft Windows 10 Pro
Processor Type and Speed: i7 - 3.26 GHz
Total Physical Memory: 16Gig
Plugins: BlBackup | EasyTrigger | FitbitSeer | HSTouchServer | Insteon | WeatherXML
Originally posted by aldo View PostIt must be me, because also by selecting 0, it still shows 0 in the battery field for all 4 sensors.
Occupancy mode sends an On every time motion is detected. is regular mode, the cycle is on, off, on, off, etcMark
HS3 Pro 4.2.19.5
CMMark
HS3 Pro 4.2.19.5
CM
please turn on detailed logging and track the before and after EEValues in your config/insteon.ini for the the motion sensor you are testing. This is an example from mine, yours may have different values:
EEValues=LEDBrightness=41,Timeout=0,Sensitivity=42
you should be able to change one or all of the settings and they will each get updated during the next programming opportunity.
i also added a red message to the top of the device edit page if there are changes pending.
thanksAttached FilesMark
HS3 Pro 4.2.19.5
That seemed to take care of that problem ...
Now I found another...
I saw this when looking at the insteon settings:
You have 15 internal Insteon device(s) registered in the system, 3 external device(s), and 0 group(s).
These devices and groups currently consume 124 link database entries in your interface.
You have 240 unused outbound link addresses out of 254 total available.
The following are unregistered Insteon addresses found in the network.
08.AA.CA found in Living Room Living Room Light
00.00.0C found in Master Bedroom Overhead Light
02.14.83 found in Master Bathroom Vanity Light
0C.49.F0 found in Master Bedroom Ceiling Fan
01.DA.E4 found in Entry Keypad Link Button A/Load: Entry Light
CMAttached FilesHomeSeer Version: HS3 Pro Edition
FYI, after I posted this, I realized the correct way to take care of the un-registered links.
Originally posted by codemonkey View PostFYI, after I posted this, I realized the correct way to take care of the un-registered links.
CMMark
HS3 Pro 4.2.19.5
Originally posted by aldo View PostHi Mark,
I tried the last beta plugin, unfortunately the battery voltage for the motion sensor is still shows as 0. Anything that I'm missing?Mark
HS3 Pro 4.2.19.5
