For the 3rd time in 2 weeks, my HomeSeer shutdown for no apparent reason. Noticed events were not running and found the system not running.
PC was running fine and this is a dedicated machine.
No error log in the config folder.
Log offers no clues.
2/18/2012 8:36:08 PM ~!~Device Control~!~Device: 1st Flr Family Room Valance Lights (\44) OFF
2/18/2012 8:36:09 PM ~!~Device Control~!~Device: 1st Flr Kitchen Soffit Lighting (\64) OFF
2/18/2012 8:36:11 PM ~!~Device Control~!~Device: 1st Flr Kitchen Undercabinet Lights (\65) OFF
2/18/2012 8:36:12 PM ~!~Device Control~!~Device: Basement Bath, Bsmt Sauna Lights ON (\91) OFF
2/18/2012 8:36:26 PM ~!~Device Control~!~Device: Basement Bath, Bsmt Ceiling Lights (]3) OFF
2/18/2012 8:36:43 PM ~!~Device Control~!~Device: 1st Flr Hallway, 1st Floor Ceiling Lights Primary (\62) OFF
2/18/2012 8:36:50 PM ~!~Device Control~!~Device: 1st Flr Dinette Dinette - Ceiling ON load (\66) OFF
2/18/2012 8:36:52 PM ~!~Device Control~!~Device: Exterior Exterior Receptacle, Main Deck (_36) OFF
2/18/2012 8:36:53 PM ~!~Device Control~!~Device: Exterior Exterior Receptacle, Mstr Deck (_37) OFF
2/18/2012 8:36:59 PM ~!~Device Control~!~Device: 1st Flr Family Room Fireplace Spot (\16) OFF
2/18/2012 8:42:57 PM ~!~Startup~!~
2/18/2012 8:42:57 PM ~!~Startup~!~*********************************************** *********************************
2/18/2012 8:42:57 PM ~!~Startup~!~ HomeSeer version 2.5.0.49 Starting Now (Standard Build)
2/18/2012 8:42:57 PM ~!~Startup~!~Using system's regional settings
2/18/2012 8:42:57 PM ~!~System~!~Ending plug-in process hs_compatibility
2/18/2012 8:42:57 PM ~!~Startup~!~Creating Class Objects...
2/18/2012 8:42:57 PM ~!~Startup~!~COM port classes started.
2/18/2012 8:42:57 PM ~!~Startup~!~Application interface class started.
2/18/2012 8:42:57 PM ~!~Startup~!~Web server class started.
2/18/2012 8:42:57 PM ~!~Startup~!~E-Mail SEND class started.
2/18/2012 8:42:57 PM ~!~Startup~!~E-Mail RECEIVE class started.
2/18/2012 8:42:57 PM ~!~Startup~!~Z-Wave class started.
2/18/2012 8:42:57 PM ~!~Startup~!~Plug-In Interface class started.
2/18/2012 8:42:57 PM ~!~Startup~!~Speech recognition class started.
2/18/2012 8:42:57 PM ~!~Startup~!~HSPhone dialer class started.
2/18/2012 8:42:57 PM ~!~Startup~!~Loading Settings
2/18/2012 8:42:57 PM ~!~Warning~!~HomeSeer was not shut down successfully the previous time it was started.
2/18/2012 8:42:57 PM ~!~Database~!~HomeSeer is performing database maintenance on homeseer 091810.mdb
2/18/2012 8:42:57 PM ~!~Database~!~Database maintenance Completed Successfully.
2/18/2012 8:42:58 PM ~!~Startup~!~Settings Loaded.
2/18/2012 8:42:58 PM ~!~Startup~!~Current sunrise/sunset values calculated.
2/18/2012 8:42:58 PM ~!~Startup~!~HSPhone external interface class started.
2/18/2012 8:42:58 PM ~!~Startup~!~Local voice recognition class started.
2/18/2012 8:42:58 PM ~!~Startup~!~Database SAVE process started.
2/18/2012 8:42:58 PM ~!~Startup~!~Loading configuration file ...
