Hi All
I'm looking to change my z-wave thermostat. I currently have the 2gig model with BLStat. Things I don't like are:
I originally bought it because I didn't have a c-wire, but I figured out where to run it from and now have one.
My philosophy with my home automation is to make sure all critical systems work if the server is off (lighting, heating, security)
Features:
Any recommendations
Mark
- Can't control locally when paired
- Schedule is only in HS, so doesn't work when HS is down
- Doesn't report status, so have to poll to get current values
- Value on T-Stat frequently different to HS
Features:
- I'd like one where the schedule can be stored locally and uploaded, so it's easy to switch from normal to vacation if I go away for weekend.
- I'd like to be able to override the current setpoint (so I can adjust heat, or turn on/off outside of normal schedule)
- Must be able to control from HSTouch actions and scripts (when I set my alarm HS knows, so can drop the heating temp)
- Would consider a wifi version as long as it can be controlled via HS
- WAF > 7/10 (very subjective )
Any recommendations
Mark
