This plugin is designed to allow HomeSeer to control any instance of Kodi running on your local network.
Please report any bug.
Please read the User Guide before installing.
Installation:
Changes to v3.0.1.14
- Added "Player Open Media > Playlist" action
Changes to v3.0.1.13
- Fixed status device by relying on Play/Pause notifications rather than the speed field
Changes to v3.0.1.12
- Fixed problem due to changes in Kodi version 18 (Leia)
Changes to v3.0.1.11
- Added "Player Enable Party Mode" and "Player Disable Party Mode" event actions
- Added possibility to delete an unused player from config page.
Changes to v3.0.1.10
- Fixed problem with new set of devices being created if the Kodi instance has its name changed
Changes to v3.0.1.9
- Fixed PlayerOpenMedia scripting function so that it match the "Player Open Media" event action
Changes to v3.0.1.8
- Changed avahi lib to fix discovery problems on Linux.
Changes to v3.0.1.7
- Added optional "Image URL" parameter to the "GUI Show Notification" action and scripting function
Changes to v3.0.1.6
- Added "Profile Load" event action
- Added optional devices for music (artist, album, genre) and PVR (channel, channel number)
- Fixed problem with shuffle and repeat controls
Changes to v3.0.1.5
- Fixed problem with thumbnail and fanart images for music
Changes to v3.0.1.4
- Fixed problem with download of thumbnail and fanart images
Changes to v3.0.1.3
- Ping Kodi player every minute and try reconnecting if disconnection is detected
- Fixed duplicate TCP connection when the Kodi machine has several IP.
Changes to v3.0.1.2
- Added possibility to play a favourite using the "Player Open Media" action
Changes to v3.0.1.1
- Fixed error when movieid = 0 preventing status device to be updated.
Changes to v3.0.1.0
- The XBMC plug-in was renamed Kodi
Read this post for details on how to upgrade to this version
Changes to v3.0.0.41
- Log all JSON traffic at debug level
- Added possibility to log to file
Changes to v3.0.0.40
- Support for Kodi TCP server running on a port different from 9090
- Fixed problem with zeroconf lib (used for discovery) getting stuck sometimes
Changes to v3.0.0.39
- Fixed some Connection/disconnection issues.
Changes to v3.0.0.38
- Added channel name as a dropdown list for the "Player Open Media" action
Changes to v3.0.0.37
- Fixed title for streamed TV Shows
- Fixed copy/paste of actions/triggers
Changes to v3.0.0.36
- Evaluate global variables for message sent with the "GUI Show Notification" action
Changes to v3.0.0.35
- Added channel as a possible media type for the "Player Open Media" action
- Strip out {} or <> tags from notifications
Changes to v3.0.0.34
- Added possibility to add parameters to the "Execute Addon" action
Changes to v3.0.0.33
- Added GetCurrentstereoscopicMode scripting function
- Fixed "Switch Player" action
Changes to v3.0.0.32:
- Fixed thumbnail and fan art image not showing in HSTouch
Changes to v3.0.0.31:
- Added device for Fan Art
- Added GetCurrentAspectRatio scripting function
Changes to v3.0.0.30:
- Linux support
Changes to v3.0.0.29:
- Added value/status pairs for Type and Media Type devices
Changes to v3.0.0.28:
- Added GetCurrentMediaType and PlayerOpenMedia scripting functions
- Fixed backward compatibility issue with music
Changes to v3.0.0.27:
- Added GetCurrentTime and GetTotalTime scripting functions
- Fixed backward compatibility issues
Changes to v3.0.0.26:
- Added "Switch Player" action (needs XBMC/Kodi version 14 or later)
Changes to v3.0.0.25:
- Added "Enable Addon" and "Disable Addon" actions
Changes to v3.0.0.24:
- Added display time as a parameter for GUI Notifications
Changes to v3.0.0.23:
- XBMC plugin as Speak Proxy to send GUI Notifications
Changes to v3.0.0.22:
- Added GUIShowNotification as a scripting function
Changes to v3.0.0.21:
- Added Disconnected and Connected status values to the root device.
Changes to v3.0.0.20:
- Fixed crash when XBMC is not shutdown gracefully.
Changes to v3.0.0.19:
- Title device for tv shows is now formatted as "<TV Show Title> SXXEYY - <Episode Title>"
Changes to v3.0.0.18:
- Added "Execute Addon" action
Changes to v3.0.0.17:
- Added "Connect" and "Disconnect" actions and buttons
Changes to v3.0.0.16:
- Added "Application Quit" Action
- Added possibility to ignore XBMC instance by adding <id>###enabled=false in the PLAYERS section of XBMC.ini
Changes to v3.0.0.15:
- Added "Rewind" and "Fast Forward" buttons to the Status device
- Possibility to suppress hs header and footer on player page
- Cosmetic changes in config page
Changes to v3.0.0.14:
- Added "GetCurrentMediaID" and "GetCurrentGenre" scripting functions
Changes to v3.0.0.13:
- Added "Send Text" text box to the "Remote Control" device
Changes to v3.0.0.12:
- Added File media type to "Player Open Media" Action
Changes to v3.0.0.11:
- Added "Remote Control" device
Changes to v3.0.0.10:
- Fixed problem with XBMC notifications that stopped working when several ones were received at the same time..
Changes to v3.0.0.9:
- Added "Player Open Media" Action.
Changes to v3.0.0.8:
- Fixed "GUI Show Notification" Action.
Changes to v3.0.0.7:
- Added "MPAA Rating" device.
Changes to v3.0.0.6:
- Added "Media Type" device.
Installation:
- download the zip attached to this post and save it in the HS3 application folder in /Updates3/Zips
- download the file named updater_override.txt attached to this post and save it in the HS3 application folder.
- go to the "PLUG-INS > Manage" page and click the "Update Listing" button, then click "Additional interfaces > Kodi Plugin" and check the Kodi line.
- click the "Download and Install" button
- enable the plugin from the "PLUG-INS > Manage" page
- delete updater_override.txt from your HS3 application folder
Changes to v3.0.1.9
Changes to v3.0.1.8
Changes to v3.0.1.7
Changes to v3.0.1.6
Changes to v3.0.1.5
Changes to v3.0.1.4
Changes to v3.0.1.3
Changes to v3.0.1.2
Changes to v3.0.1.1
Changes to v3.0.1.0
- Linux support
