Is there a "Toggle" function available (i.e. If ON then turn OFF or If OFF then turn On) for Insteon type Events or do I need to write 2 events for each control function?
I'm using a single Insteon Switch on the Keypadlinc to control a light. I know I can create an event that "if switch Set To On AND Dimmer OFF then send device ON" but this will take 2 events for each function (1 for ON and 1 for OFF).
HSdesigner has a "Toggle" function and I just wanted to know if the Insteon plugin might have a way of doing this.
Doug
Doug
