Growl plugin?
    Growl plugin?
    Does anyone know how to setup the Growl plugin that is in the library?
    This is how I just did it. (I think, may miss a step here)
    - Download and install Growl for Windows - http://www.growlforwindows.com/gfw/. This can be any computer(s) on your network. Doesn't need to be running on the HomeSeer computer either.
    - Launch Growl
    - On the 'Security Page', click 'allow network notifications'
    - click the '+' and create a password
    - Shutdown HomeSeer
    - Drop into your HomeSeer directory, the 3 .dll's downloaded (the plug-in) from http://forums.homeseer.com/showthread.php?p=885186
    - Start HomeSeer
    - Go into 'Tools', 'Setup/Config', 'Interfaces'
    - Enable 'Growl' and then scroll to bottom and 'Save'
    - On same page, go into the 'Config' for Growl
    - enter the password you created within Growl
    - enter the ip address for the computer(s) running Growl
    - Click 'Save'
    - I then shutdown HomeSeer and restarted (may not be necessary)
    Once HomeSeer finishes loading, take a look at the computers running Growl. Select the 'Applications' tab, HomeSeer should now be listed!
    From here on you can go back to Dale's post to see how to send the messages.
    Hope this works for you, it took me some time to figure out how to set this up without any documentation.
    Bryan
    Software/Hardware: Win10 Pro, HS 3 Pro, HS Touch, Echo, Edgeport/4, Z-Net w/88 Devices, Insteon PLM w/19 Devices, Nest, GC-100-6, W800RF32A, WS-2080 Weather Station (KMADRACU10)
    Plug-in/Scripts: Alexa API, BLBackup, BLGData, BLLED, BLLock, BLRF, BLTVGuide, Blue Iris, BLUPS, Current Cost 3P, DirectTV, FitbitSeer, Insteon, Nest, Pushover 3P, Random, Restart, Tasker, UltraGCIR3, UltraWeatherWU, Z-Wave
