RFXtrx433 and Irox
    RFXtrx433 and Irox
    Anyone know if Irox weather sensors are readable by RFXCOMM ?
    Cheers
    Scott
    In addition to Irox, does anyone know if it also supports Somfy blind motors?
      It seems some of the Irox sensors are compaible with TFA, Honeywell, Nexus, Mebus and Cresta. But it is not yet known which sensors are compatible.
      The TFA types supported are TS15C and TS34C.
      And a TFA wind, rain and UV sensor is supported (type unknown)
        Thanks Bert - Some of the sensors were compatible, but I have replaced them all with Oregon.
        I have a Worcester Bosch 433MHz thermostat which looks like is being received by RFXCOM - If I send you the code can you decode it?
        Cheers
        Scott
          Scott,
          I appreciate to receive information if packets are received using undec on in RFXmngr.
          I need the undec message , sensor brand and type and the value displayed by the sensor or master station at exactly the same time as the undec message is received.
          Bert
            Hi Bert
            The Thermostat is a Worcester Bosch DT10RF - here's the link
            http://www.worcester-bosch.co.uk/hom...ptimiser-mk-ii
            I turned the thermo off and on twice - the codes recvd by RFXLAN are:
            off (RecRxChar) receiver #1 packet: 581A8904C8F0C0256002549F
            on (RecRxChar) receiver #1 packet: 50FA2814B6801340C9542D
            off (RecRxChar) receiver #1 packet: 581A8904C810C02210023EC1
            on (RecRxChar) receiver #1 packet: 581A8904C800C02550024490
            Hope that is of use
            Cheers
            Scott
              The commands are received from a WGR800 and THGR810, not from the thermostat!
              And this is not a normal RFXtrx433 output but an RFXCOM receiver or RFXtrx433 wrong configured as receiver and using very old firmware. The option to use the RFXtrx433 as receiver has been eliminated.
                Cheers Bert - I'll have another go.
                I have a 433.92MHz LAN transceiver not an RFXtrx433 - dont know if that makes a difference regarding the old firmware??
                I'll let you know if I manage to get the code
                Cheers
                Scott
                  Hi Bert
                  Could either of these be the ones?
                  (RecRxChar) receiver #1 packet: 6C2A83FF0704600C78360100F0A510
                  (RecRxChar) Unknown packet: 4C1A8904C800C025800146
                  If not, any suggestions how to capture the transmissions?
                  Cheers
                  Scott
                    Only the listed protocols are supported.
                    The packets are from Oregon sensors.
                    We have to make the conclusion that the thermostat cannot be received.
                      Cheers Bert, Looks like you are right!
                      Thanks for trying
                      Scott
