ImperiHome Plug-in - Beta Testing
    #61
    Originally posted by spud View Post
    it's bug, sorry for that, it will be fixed in version 3.0.0.2
    Great. I also noticed when editing the sensor fields, whatever text is already in the field, does not appear in the popup used for editing the text.
    Al
      #62
      Al
        #63
        Does this work on linux ?
        How to install ? Says it cant find the zip file.
        Edit: found it. Path is Updates3/Zips. The installation instruction mentioned lower case paths
          #64
          Al
          This happens because when you add or change something in the sensors tab, the plugin only does a partial refresh of the page. I'll try to see if this can be fixed, but I doubt it. The workaround is to force a full refresh by hitting F5.
            #65
            It should work on Linux, but I haven't tested it yet on this platform, so let me know if you have any problem.
              #66
              Thanks, I will do that for now. Any thoughts on the issue I posted in post #55?
              Al
                #67
                Thanks Spud. I appreciate your responsiveness for your plugins.
                All working well and looks like your enhancements in the works will make this quite a useful little tool.
                I edited my original post
                EDIT: SOLVED
                Can't access through Imperihome setup OR another Ipad
                Firewall is off. (Didn't realize my computer was set with 3 layers of firewalls)
                  #68
                  You can also go into the character map in accessories under the start menu. That is what I do, but didn't know about the code .
                    #69
                    The thermostat does not seem to support hot/cold set points.
                    Expected: Can change hot and cold set points when opening thermostat widget.
                    Actual: Only shows cooling setpoint (which is all unopened widget can do, but opening widget should show hot and cold).
                    This is how it worked when I used Vera with Nest Plugin vs HomeSeer with Nest Plugin.
                      #70
                      Hi spud,
                      When deleting devices in HS, I get the following entries in the log:
                      ImperiHome ERROR System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_ImperiHome.ISSCache.RemoveDevice(Int32 dvRef)
                      Al
                        #71
                        Currently I don't think the API is able to handle this. I will ask ImperiHome developer if it can be added.
                          #72
                          Hi spud,
                          Al
                            #73
                            in version 3.0.0.2 available in first post, I have added support for security devices and fixed some of the bugs reported in this thread.
                              #74
                              Thanks spud, looking good so far!
                              Cheers
                              Al
                                #75
                                Just a heads up Imperihome dropped Beta B370 today and it added Sonos support, And iOS support for export files along with a few other things.
                                So good progress on both sides here.
