Getting Error at IF PLUGIN IS
    If i want to create an event like : Easytrigger: If plugin is... i select it but i cant put anything nothing shows up.
    when i go to and if it shows up and i can set it up...
    when i delete the first if it saves but its bugged somehow..
    see screenshots
    Nothing shows up
    Second IF
    When i delete the first IF
    HS3Pro 4.1.14.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
    I admit it's a bit confusing but "A plugin is" can only be used as condition (AND IF) and not as a trigger (IF or OR IF). That's why you can't select anything when it's a trigger.
    Unfortunately the HS API does not allow me to remove it from the list only for triggers, I will try to add an error message in a future version though.
      Ok
      Many thanks for the reply spud.
      i am stupid myself, i didn't see this note haha
      Note: Even if it appears in the list of triggers, this one can't be used as a trigger (IF, OR IF) it can only be used as a condition (AND IF)
