Logitech Harmony Ultimate (Hub) Plugin
    #46
    This is looking very promising...I'd like to sugest adding Location2 field for the Hub.
    HS Install Date: Feb. 16, 2007
    HS3 Pro, Z-Wave, Insteon, BLStat, HS Touch Server, MyQ
    WeatherXML, BLBackup, BLLAN, BLLock, Restart, CaddX, OpenSprinkler
      #47
      Rien,
      Great work, looks good
      BArt
      Regards Bart
      Win7 64Bit on Intel NUCI7 with SSD
      HSPRO 3.
      Devices; 1370 Events; 691
      Jon00 Scripts, JowHue, HSTouch, Plugwise, Z-wave, Ultranetatmo, Ultracam, PHlocation, BLUSBUIRT, MeiHarmony, Buienradar, MEiUnifi Pushover 3P, Random, Nest HSPhone and Blueiris
      Visonic Powermax Alarm System (HS3) Interface: http://www.domoticaforum.eu/viewtopic.php?f=68&t=11129
        #48
        And here is the devices screen with activities
        Rien du Pre
        The Netherlands
        Using:
        Plugin's:
        RFXCOM, mcsMQTT, Z-Wave
          #49
          Is there any feedback from the hubs? For example is there a way if, for example, someone uses the Harmony remote to fire things off that HS can be notified?
            #50
            The only way is to poll the hub from the plug-in. If someone have started an activity the hub knows that and the plug-in will know it too after the hub is polled....
            As long as there is no public api with extensive functionalities I cannot do more than this....
            Rien du Pre
            The Netherlands
            Using:
            Plugin's:
              #51
              Then it would be Nice to be able to poll with an event.
              Verstuurd vanaf mijn Nexus 5 met Tapatalk
                #52
                Hi Harry,
                You mean besides the polling interval you can specify in the plugin config ?
                Rien du Pre
                The Netherlands
                Using:
                Plugin's:
                  #53
                  The Harmony Hub plug-in has been submitted in the HS3 updater, as soon as it's available for download I'll let you all now !!!!
                  Rien du Pre
                  The Netherlands
                  Using:
                  Plugin's:
                    #54
                    Amazing! Can't wait to give it a try.
                      #55
                      Awesome! Totally excited about this!
                        #56
                        Originally posted by Rien du Pre View Post
                        Hi Harry,
                        Yes. Because than you van create a screen in hstouch which triggers the poll when opened. Or you can put a poll in an event to check device conditions to match the status of the harmony hub.
                          #57
                          Rien,
                          Will it be possible to send individual IR command by use of the released plugin? Such as volume+/- , temperature up/down etc?
                          And as already stated, but i know the limitation, it would be great to get the hub push changes to the plugin;
                          Create a dummy Harmony device, to control devices in homeseer. As soon as u use the physical remote to control the virtual device, the plugin will recieve those command from the hub and can interact which the devices in homeseer.
                          Regards and thanks for the great work Rien
                          Bart
                          Regards Bart
                          HSPRO 3.
                            #58
                            Originally posted by bartbakels View Post
                            Rien,
                            Bart
                            Hi Bart,
                            Than every IR command would take 15-20 seconds to complete, which would make it totally unusable in my opinion. Volume up 3 points would take a minute :-(
                            I haven't tried yet, but it would be easier to create a dummy activity with the IR command you would like to sent and run that activity from HS.
                            Rien du Pre
                            The Netherlands
                            Using:
                            Plugin's:
                              #59
                              Hi Bart,
                              Rien, please explain the above further? Why would sending an individual IR command take 15-20 seconds?
                              Sent from my iPad using Tapatalk HD
                              Author of Highpeak Plugins | SMS-Gateway Plugin | Blue Iris Plugin | Paradox (Beta) Plugin | Modbus Plugin | Yamaha Plugin
                                #60
                                The way it is done now, that I have to authenticate to the internet/Logitech account and the hub first to sent a single command, This authentication takes a long time unfortunately.
                                I am looking for other ways to sent a sequence of commands after authentication, but for this first release this is not supported....
                                Rien du Pre
                                The Netherlands
                                Using:
                                Plugin's:
