What's the process to have the RA2 devices already in HS3 changed if there's edits made externally with Lutron's software?
What's the best method to avoid complications?
Is the plugin tracking them inside HS3 based on the Lutron IntegrationID? That is, if I use the button on the plug-in config page will it only add things with an IntegrationID it's never seen before?
I don't see doing this all that often. But during the initial stages of learning/configuring HS3 there's the potential for a lot of doing-and-re-doing stuff that could potentially get messy.
