You should be able to verify that your name server lookup (DNS) is working by comparing the results from working & non-working machines.
Open a Windows cmd window (Start->Run-> cmd) and enter the following command:
This is what I get:
You might get different results from your location, but you want results between two computers on the same network to match.
If not, first check if the server addresses match. If not, you likely have a static IP address assigned and have different nameservers specified for the two machines. (If you are using DHCP, the nameserver address is provided by the router and you don't have to worry about this).
Another thing to check is the hosts file
C:\Windows\System32\Drivers\etc\hosts
Generally I'd expect this to be empty unless you are doing something fancy.
nslookup www.wunderground.com
C:\Users\Me>nslookup www.wunderground.com Server: UnKnown Address: 192.168.1.1 Non-authoritative answer: Name: e12930.g.akamaiedge.net Address: 23.210.206.170 Aliases: www.wunderground.com wunderground.com.edgekey.net
