Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > UPB plugin by Spud (3P)
UPB plugin by Spud (3P) Spud UPB plugin discussions.
Old June 19th, 2015, 12:00 PM
Daweeze's Avatar
Daweeze Daweeze is offline
Seer Deluxe
Simply Automated UPB UCQF-W 3-Speed Fan Controller
Hi Spud,
I just ordered a few of the new Simply Automated UPB 3-Speed Fan Controllers and wanted to see if you could set them up so they import correctly int the plugin.
Product Link Here:
http://www.simply-automated.com/prod...ller_white.php
Product Sheet Here:
http://www.simply-automated.com/docu...-W)_140404.pdf
Manual Here:
http://www.simply-automated.com/docu...ide_140415.pdf
It essentially is a 4 Button Controller with Off/Low/Medium/High options. It also has an ability to switch (not dim) a light which I am not using. That said, each button is also a scene switch and activates a scene if preferred. The Scenes are working as expected and imported and operate fine. I just cant seem to get it to show up as a consolidated device. Each button on the device is a separate channel import as shown shown in the attachment.
I have also attached the .UPE File information for that controller. Please let me know if you can help or if you need anything else from me.
-Travis
File Type: zip ForSpud.zip (536 Bytes, 21 views)
Old June 19th, 2015, 02:20 PM
spud's Avatar
spud spud is online now
Moderator
this is the expected behavior, each channel is represented in HS as a "UPB Device" device that basically represent one physical button + associated indicator light
the plugin should also have created the 4 "UPB Link"devices, representing the links for High/Medium/Low/Off
so what's not working exactly?
Old June 27th, 2015, 06:25 PM
Daweeze's Avatar
Seer Deluxe
Hi Spud,
I am fairly new to HS and rather a basic user at that. Previously I used HAI HLC to easily program my UPB system so please bare with me on the rough explanation below:
Here's what I am finding even though maybe the UPB functionality is importing perfectly. What I would like to see (if possible) is one unified device presented for this switch so it appears like the wall switch it is.
In HS, it would be like a Light Switch that had Off/Low/Medium/High selections. Of course the individual UPB Links and maybe even the lights would be separate. Otherwise, it works perfectly physically but in HS acts a little strange.
For instance, locally when "Off", pressing "Low" on the switch does the following:
1) Off LED Turns Off
2) Low LED Turns On
3) Low Fan Speed Relay (Inside the Switch) Powered
In HS though, when you activate a link, things work fine. Moving from low to High acts accordingly in fan speed and LED's on the switch. When you use I suppose the devices created for the LED's, the fans will power up and light both the LED and power the motor at that speed. For instance, toggling to the On selection powers the LED and the Motor control and you can have both Low and Medium powered at the same time which actually runs the fan at the combined Low/Med speed of High due to both speed relays being on at the same time. So then you have invalid indications so you have no idea what speed you are really at as Low and Medium LED's are light but the fan is at high speed. I corrected this issue from happening by changing the indicator devices Status-Control to "Status" but they did not import that way.
I suspect I should remove all of the normal options for the UPB Links for the fans as well except for Activate and Deactivate as there is not dimming function and using "On" turns on all the LED's and speeds on the controller which is not helpful. Are these settings that you can setup so this model of device inherits a specific template when it is detected or do I need to modify each of these manually in the future.
So basically, after modifying the Status/Control I am left with a usable solution but is there a way to create a Fan Device that is essentially a Virtual Device that sends the "Activate" UPB Link commands for Off, Low, Medium and High? Even having a slider which triggers Links at 0/1-33/34-66/67-100 would be appropriate or is that another idea for another SPUD Plug-In?!?!?!
Also, I was curious about the link status in the HS Device List. I noticed that the default is "Activate", I suspect this is tied to the Last Change Time/Date so you know what time it was last activated since it's a control and not necessarily a Status. That said, by default it looks like all links were activated when you boot up HS which we know is not true. Wouldn't the default Status be Deactivate if the link hasn't been activated since the last start of HS? Not sure about this, I may be missing something here.
-Travis
Old July 6th, 2015, 11:58 AM
Daweeze's Avatar
Seer Deluxe
Bump
Old July 6th, 2015, 02:07 PM
spud's Avatar
Moderator
sorry for the delay
let me try to explain what happens here:
Each of the 4 "Ceiling Fan - Ch X" devices represents a UPB channel, i.e. the status and control of a load and the associated indicator light. This is easier to understand if you see this for example as a switch with 4 buttons that would control 4 different loads, in this case the 4 loads and indicator lights could be turned On at the same time. In the case of this specific Fan controller device it makes a little less sense because the 4 channels actually control the same load but with different levels, so only one of them can be On at the same time. When you physically press one button on this controller what actually happens is that one link is activated which turn on one of the channel and turn off the 3 other channels, this is different from clicking the On button of a channel device which only turn on one channel.
So this device is a mix of a switch (controlling a load) and a keypad (that send links to control other loads), but is defined more like a switch by the plugin because in the .upe file there is no "Button record", so the plugin doesn't even know this device has buttons.
What you can do is manually create a virtual device with 4 buttons (Off/Low/Medium/High) and create one event for each button that will Activate the corresponding Link when the device is set to this value.
Regarding Links, "Activate" means that each channel should go to it's own unique pre-programmed level, whereas On means all channel should go to level 100 (On) that's why when you click "On" it turns on all the indicator lights.
So, yes you can delete all the buttons Links except Activate. You can even delete the Deactivate button because from the controller the links are never deactivated. Each button of your physical controller has the same effect that clicking the corresponding "Activate" button in HS.
I suspect that is also why you see all links with an "Activate" status because they are never actually deactivated unless you control them with HS and the Deactivate button.
not sure this is very clear, let me know if you have questions
Old July 6th, 2015, 11:27 PM
Daweeze's Avatar
Seer Deluxe
Hi Spud,
Thanks for the response. I am running into a little trouble with the workaround. I am not sure how best to deal with what wasn't said. I setup the virtual devices for 3 of my switches and I have that working great. That said, how do I best deal with the physical press of a button (Link Activated) on the switch changing the status in the virtual device? It seems like a circular reference in my mind but I am not sure which event should get the 1 time per second limit or whatnot. How would you best deal with that in programming the event?
I attached a copy of the Event Example of what is working with HS Control. Now I need to figure out the proper or best way to do the update of the Virtual Device when someone presses the switch.
I hope that makes sense.
Thanks for your help,
-Travis
Old July 7th, 2015, 10:12 AM
spud's Avatar
Moderator
you're right, you need to avoid circular reference. To do that I would add a condition on the channel to your event:
IF "Virtual Device" changes and becomes Low
AND "Celing Fan - Ch 2" is Off
THEN Set Device "Ceiling Fan - Low" to Activate
and then another event to update the status of the virtual device when the button is physically pressed.
IF "Ceiling Fan - Ch 2" changes and becomes On
THEN Set "Virtual Device" to Low
Old July 7th, 2015, 11:51 PM
Daweeze's Avatar
Seer Deluxe
Hi Spud,
Thanks again for your time looking into this. I tried doing the programming and ran into another issue. I have turned off all events related to the fan controller for the time being to expose this issue. Something isn't working properly. Here's the example:
UPB Device ID 134 - UCQF-W 3-Speed Fan Controller
Link 105 --> (LED Device 134 CH-1) Fan Speed High
Link 106 --> (LED Device 134 CH-2) Fan Speed Medium
Link 107 --> (LED Device 134 CH-3) Fan Speed Low
Link 108 --> (LED Device 134 CH-4) Fan Off
The Debug Log is show after pressing the physical LOW SPEED BUTTON on the controller while it was in the "Off" Mode. What is actually happening is that the Physical controller goes to "Low Speed" and the Indicator turns on correctly. However in HS, Both the High(CH1) and Low(CH3) Device Indicators are turning to "On".
Jul-07 8:29:19 PM UPBSpud DEBUG PIM_RCVR:: Received UPB command [PU08150100868604D2]
Jul-07 8:29:19 PM UPBSpud DEBUG DEVICE[134]:: Level changing on channel 0 from 0 to 4
Jul-07 8:29:19 PM UPBSpud DEBUG PIM_RCVR:: Received UPB command [PU08140100868604D3]
Jul-07 8:29:19 PM UPBSpud DEBUG LINK[107]:: Got Link ACTIVATE
Jul-07 8:29:19 PM UPBSpud DEBUG PIM_RCVR:: Received UPB command [PU8915016B8620FFFF52]
Jul-07 8:29:18 PM UPBSpud DEBUG DEVICE[134]:: Level changing on channel 3 from 100 to 0
Jul-07 8:29:18 PM UPBSpud DEBUG DEVICE[134]:: Level changing on channel 2 from 0 to 100
Jul-07 8:29:18 PM UPBSpud DEBUG LINK[107]:: Got Link ACTIVATE
Jul-07 8:29:18 PM UPBSpud DEBUG PIM_RCVR:: Received UPB command [PU8914016B8620FFFF53]
Any idea how to determine why this is happening?
I am unsure what the channel 0 reference is for. I tested further and it appears that the following is being logged in the log reference:
Ch0 = High,
Ch1 = Medium
Ch2 = Low
Ch3 = Off
in HS the Device Addresses are as follows:
1-D134-C1 - High
1-D134-C2 - Medium
1-D134-C3 - Low
1-D134-C4 - Off
Since Channel 0 is shown is this an enumeration problem in the Plug-in import it looks like the actions are off by a value of 1 and Channel 0 has values that aren't even defined (like 4).
Soooo confused!
-Travis
Old July 8th, 2015, 01:51 PM
spud's Avatar
Moderator
The log shows channels with 0 based index because this is what is used internally, I agree this can be confusing but the following part of the log is correct and expected
it means the PIM has received the Link 107 message so it turns on the Low channel device and turned off the Off channel device
what I don't understand is the other messages you got:
those message are state report that say the High channel has been set to the level 4. This explains why you see the High channel device set to On, but I don't understand why this message is sent.
When this happens can you try to select the channel device on the management page, and click the poll button to see what state report message is sent in this case.
Also what happens when you press another button on the controller, do you always get this extra message?
Old April 27th, 2016, 10:20 PM
email68 email68 is offline
Seer Master
I just installed one of these devices and wondering if the work around was fully vetted.
-Tim
HSPro - 3.XXX - Dell mini W7 x32
Way2 Call
Elk M1 Gold
UPB HAI switches
HAI RC2000 Thermostat
Old May 3rd, 2016, 04:27 PM
Seer Master
Ping! Love to get this fan controller working.
Old May 3rd, 2016, 04:32 PM
spud's Avatar
Moderator
Quote:
did you try the controller with the plugin?
if so what problem are you facing?
Old May 3rd, 2016, 04:39 PM
Seer Master
Yes. I have your plugin. Love it btw.
The upe file imported the fan as four devices or channels.
1=off
2=low
3=medium
4=high
If the fan is on medium and you send the on command for low, both the low and medium indicators are on.
I also think the low and med speeds add together when both are on, making the fan faster than low or medium.
Would it be possible to have one device with four buttons, off, low, med, high, where only one state can be active at a time?
Old May 3rd, 2016, 04:56 PM
spud's Avatar
Moderator
1=off
2=low
3=medium
4=high
rather then using the On/Off buttons of the channel devices, try to use the Activate buttons of the link devices
Old May 4th, 2016, 02:02 AM
Seer Master
I was able to test with the links tonight. That seems to work fine with expected results. Thanks!
  #16
Old May 4th, 2016, 12:35 PM
Seer Master
Spud- I see the problem now.
The links can and do activate the fan switch properly, just as if you pressed the switch on the fan controller itself. The problem comes in when you want HS to know the current state of the fan controller.
As it operates now, there is no way to know if the button is pressed manually.
So if you want an event set the fan speed to medium when its hot, but someone had already manually set it to high, you don't want to lower the speed. Just an example why HS needs to properly track the fan controller state.
I don't know if its possible because of the nature of the fan controller to do this with a plugin or not.
  #17
Old May 4th, 2016, 02:25 PM
jlrichar's Avatar
jlrichar jlrichar is offline
Seer Master
I don't have one of these yet, but perhaps you can configure the switch to receive some links. The received links would be separate from the button activations. Seems like this would be easy to setup as long as you can configure a received link to activate a specific speed. Then you would create one UPB link for each speed you want to be able to activate with homeseer.
_______________________________________________
HS3 : HSpro (3.0.0.318) on Win2012 (vm on ESXi)
Plugins: HSTouch, UPBSpud, Kinect, Nest, IFTTT, DirecTV, EasyTrigger, Imperihome, Zwave, RFXcom, UltraMon3, UltraWeatherBug3, UltraGCIR3, UltraLog3, UltraPioneer, PHLocation, Pushover, Pushalot, MCSSPrinklers S, JowiHue
Jon00 Plugins: Bluetooth Proximity, Performance Monitor, DB Chart, Links
  #18
Old May 5th, 2016, 11:37 AM
Daweeze's Avatar
Seer Deluxe
Hi Spud,
I am beginning to mess with these fan controllers again and was wondering if this is normal for every plugin restart for every fan controller I have (I have 4 of these now):
May-05 8:41:12 AM UPBSpud DEBUG UPStart_IMPORT:: device 134 is not a keypad, ignoring button record
May-05 8:41:12 AM UPBSpud DEBUG DEVICE[134]:: Marked device Ceiling Fan (134) as NON-DIMMING
May-05 8:41:12 AM UPBSpud DEBUG NETWORK[2]:: Added Room [Aubrie's Bedroom] -- 3 rooms now known
May-05 8:41:12 AM UPBSpud DEBUG UPStart_IMPORT:: Receive Component Count mismatch on deviceID 134 between import file (8) and device (16)
May-05 8:41:12 AM UPBSpud DEBUG UPStart_IMPORT:: Transmit Component Count mismatch on deviceID 134 between import file (0) and device (1)
May-05 8:41:12 AM UPBSpud DEBUG UPStart_IMPORT:: Channel Count mismatch on deviceID 134 between import file (4) and device (1) -- updating device
May-05 8:41:12 AM UPBSpud DEBUG Product Code/ID: 52
May-05 8:41:12 AM UPBSpud DEBUG Manufacturer Code/ID: 4
May-05 8:41:12 AM UPBSpud DEBUG A new generic UPB Device found!!
I am just trying to make sure that all of the imports for these devices are as expected before I try to integrate them again.
Specifically these three lines.....are they an issue and why would they be a mismatch with every plugin restart?
-Travis
  #19
Old May 6th, 2016, 09:46 AM
Daweeze's Avatar
Seer Deluxe
Hi Spud,
Resuming our issue from the past with this device, here's a simple issue that we can test with fixes since I have a test switch now setup.
Switch Physical Status - Off Indicator Lit, Homeseer Off Indicator Lit (On)
Then Press Off on the Physical Switch:
Here's the Log:
May-06 6:41:08 AM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
May-06 6:41:08 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU08050200878608DC]
May-06 6:41:07 AM UPBSpud DEBUG DEVICE[135]:: Level changing on channel 0 from 0 to 8
May-06 6:41:07 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU08040200878608DD]
May-06 6:41:07 AM UPBSpud DEBUG UPB_RCVR:: Message already received and treated -- message ignored
May-06 6:41:07 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU890502048720FFFFC7]
May-06 6:41:07 AM UPBSpud DEBUG Device 135 transmitted link 4 with action Activate => Firing event 9686
May-06 6:41:06 AM UPBSpud DEBUG LINK[4]:: Got Link ACTIVATE
May-06 6:41:06 AM UPBSpud DEBUG UPB_RCVR:: Received UPB command [PU890402048720FFFFC8]
Here's what happens:
The Indicator Device for the High in HomeSeer changes to On. The original Indicator Device for Off Remains Lit. The physical device is as expected (Only Off LED lit).
Using Upstart only to control links and the physical switch never seems to have an issue. I attached the UpStart configuration screenshots this time.
Any ideas for the incorrect tracking of the HS LED Indicator status?
-Travis
  #20
Old May 6th, 2016, 10:45 AM
spud's Avatar
Moderator
I'm confused by your test , do you try to change from High to Off, or from Off to High? because you said Off indicator lit, and then you say you press the Off button on the physical switch.
the following message is definitely weird:
It is as if the level on channel 0 was binary coded to represent the state of all indicators or something like that.
HTML code is Off
HAI / Simply Automated GadgetBoySI Lighting & Primary Technology Discussion 4 May 13th, 2010 05:58 PM
Simply Automated PIM - USB GadgetBoySI HomeSeer UPB Plug-In (Beta) 6 May 9th, 2010 06:37 AM
Simply Automated USB PIM Oman HomeSeer UPB Plug-In (Beta) 2 November 22nd, 2008 07:08 PM
Simply Automated UPB - Random reprogramming GlennWo HomeSeer UPB Plug-In (Beta) 5 April 15th, 2008 12:29 PM
Help on UPB 3 way using Simply Automated switches Richard HomeSeer UPB Plug-In (Beta) 26 July 16th, 2007 10:50 PM
