  #101
Old April 21st, 2009, 02:22 PM
Chak's Avatar
Chak Chak is offline
I Have two charging stations with lot of plugs connected.
I can confirm that most of heavy device use lot more than the controlling device.
Like Pronto pro use about 10 watt with the extender.
I agree only the charger of most modern phones makes no sense to turn off.
  #102
Old April 21st, 2009, 05:44 PM
ljames28's Avatar
ljames28 ljames28 is offline
Seer Plus
Wow, 10 watts is a lot for a charger, that's definitely worth it then.
  #103
Old April 21st, 2009, 06:06 PM
Chak's Avatar
I hope in few years this kind of devices will be no longer allowed on the market.
Since I'm monitoring more then 30 device online I know they can make device better and green.
Example.
My Sony LCD TV will only use 0.1 watt when in standby
My old DVB-C receiver consumes 6.5 watt in standby..when online 7.5 watt.
Asus eee box with SSD 12 watt
Imac 20" 65 watt
Tilt motor of my Auping bed is using 12 watt when idle...this is crazy...i'm turining this also of when house is armed..Next step is work with sensore...when no one in bed turn off..this is 105 Khw per year..
  #104
Old June 3rd, 2009, 10:44 AM
ArbWare's Avatar
ArbWare ArbWare is offline
WOL for wireless?
Is there any such thing as Wake On Lan for wireless connections?
If so.. i assume not all Wireless adapters support it..
(My current wireless desktop has a usb 802.11G adapter. When the PC goes to standby.. the led's on the wireless adapter go dark.. so i assume it is could not receive a "magic packet".)
Does anyone know if there are any WOL for wireless solutions out there?
Andrew B.
  #105
Old June 3rd, 2009, 11:50 AM
Steve Q's Avatar
Steve Q Steve Q is offline
Andrew,
I assume you are referring to a secondary computer, obviously you don't want your Homeseer computer to go to sleep. I use a program called PowerOff to allow Homeseer to put my secondary computer to sleep after 30 minutes of no motion at my desk. I think you can use this program to wake up the computer also, but I have not tried it. I just press the space bar.
Steve Q
  #106
Old June 3rd, 2009, 12:48 PM
ArbWare's Avatar
Correct.. secondary computer.. not H.S. machine.
I put it to sleep using pshsutdown from a homeseer event
I wanted to "wake it up" when someone is in the room for more than 2 minutes.. (so it would have the screen saver with pictures...)..
But i don't think you can do the WOL with a wireless connection.. so
Sometimes Non-Automation is the best (or only) route:..
If I or the family want to see pictures.. just hit the space bar.
  #107
Old June 3rd, 2009, 01:35 PM
neiltimms's Avatar
neiltimms neiltimms is offline
I don't think so Andrew.
I fooled around with for one for a while but could not find a way. Eventually i ran a wire to that computer so i didn't need a wireless solution anymore.
Running HS PRO V2.5.0.49 & HS Pro V2.5.0.51
  #108
Old August 20th, 2010, 05:15 PM
macrylinda1
Guest
Posts: n/a
Originally Posted by jackpod View Post
Well they used to have the phrase "promise to cherish and obey" I've been holding that over her head for decades! but then they also had divorce court and none of this unreconcilable differences...
The times have changed.....
This was a topic of dicussion a long time ago.
You need a digital watt metter because if I remember right the X-10 modules have a load associtated with themselves also.
Someday I hope to have HS monitor my power generating equipement when I get off the grid (long future dream).
  #109
Old October 5th, 2010, 12:57 PM
daviddwilson
Guest
Posts: n/a
Originally Posted by TeleFragger View Post
WOW I didnt think of that... I need to add that to mine!!!!! few times i have walked out of the garage and back in... and the lights shut off while I made it 1/2 way in.... this is because of the ms14a taking some time until it detects motion again (think I read every 10 seconds it checks)... so I have to wave my arms so I dont trip.... and the lights are back on!!!
But, if they aren't charging, they aren't consuming any power, right? Maybe a tiny amount for the LED that indicates the battery is fully charged but that would be negligable.
I'm asking because I have a lot of chargers in my shop that stay plugged in all the time. Maybe I need to plug them into a Kill-A-Watt to see what they pull when charging vs not charging.
_____________________
watch movies online
  #110
Old November 4th, 2010, 05:52 AM
daviidwilson
Guest
Posts: n/a
That actually was the first thing I automated. The OFF state of the equipment was in my opinion excessive and the cabinet was always warm even when everything was OFF, everything else expanded from there.
Almost all the lights inside and outside the House are set to turn off after there has been no activity in the area for a period of time. This also includes my Airpanels, TV's, Ceiling Fan's, Dehumidifier's, computers, printers, Treadmill and other items.
______________________
watch movies online
  #111
Old November 7th, 2010, 01:40 PM
Pete's Avatar
Pete Pete is offline
Even though I am not impressed with the warm color of the new low voltage LED lamps I have decided to switch over to LEDs for my landscaping lighting a zone at a time slowly.
I noticed the price of the 1-2-3 watt have dropped a lot since looking about 6 months ago. The first zone (out of about 10-12 zones) has 8 halogen lamps with 10-50 watt bulbs of all types. Each zone has a separate feed going into the house which makes it a bit easier. For this zone I will be utilizing MR-11's and MR-16's which look like the following lamps. I am trying a mix of of Cree style and multiple LED style . Already have about 3 in place. (of the cree type). Very different type of light.
Automator
  #112
Old November 7th, 2010, 11:16 PM
ViperJD's Avatar
ViperJD ViperJD is offline
GPhotoShow Screen Saver
On my HP Touch Screen Computer, I use a screensaver called GPhotoShow. It is a very nice Photo (and Video and Music) screen saver. It supports multi monitors as well, plus has alot of plugins. One plugin allows you to setup a screen off and on time.
JD Taylor
HSPRO/ X10/ Z-Wave/Z-Troller/ ZWave Thermostats / HSTouch/ Way2Call/ Andriod Client/ Win CE
  #113
Old November 24th, 2010, 01:10 AM
ellyka112
Guest
Posts: n/a
I agree... cf bulbs have reduced my electric costs...
also same goes for motion sensors... but I also use ds10a's too..
garage:
open either garage door or door to house and lights come on
after 8 minutes of no movement lights off
utility room
same as garage
crawl space
open door and light on plus motion tripped
close door and light off after motion gives an off
used to use sunset and sunrise for front porch lights (2 of them)
first went from bulbs to cf - 10hrs a day . from 36kw a month to 7.8kw
I have reduced the time even more by kicking off the porch light at 11pm and off 1hr before sunrise.....
next is for me to add a motion sensor to kick on the lights before 11pm if someone comes to the door....
ds10a on freezer, fridges (beer expecially) where you dont always go to them as I have them in the garage... this way you will know when they are open
my newest is appliance modules on all my computers except the hs machine
.... so I can turn on any computer when I want remotely to save cost...
example is I remote home now and then (as I am right now)... so hs machine is up... turn on appliance module, my computer acts as if it was a power outage and turns on.. in a few minutes I can remote in and use the machine...
I'll toss one in. Most modern electronics (A/V and computer gear) are never really "off" when you turn them off. Instant-on and IR circuitry are still active. Granted, the power draw is small... but if you add up all the gear in your house, it might be significant. Add an appliance module to a power strip and then plug your media gear into it. Then, add an event in HomeSeer that cuts power to the module during nighttime hours or when the house is unoccupied.
  #114
Old November 24th, 2010, 01:50 AM
Pete's Avatar
Finished one outdoor lighting "zone" of originally 8 Halogen lamps; now converted to LED.
I used the 12, 6, 3 , 1 LED lamp style above. the 12 and 6 are about 1.8 watts a piece and the 3 and 1 are 3 watts a piece. There is an adjacent "zone" of 4 halogen lights and current in the process of converting these. Once converted to LED will make them one "zone" of 12 LED lamps. There is a subtle color difference between the 12 and 6 LED lamps. Brightness is the same as replaced halogen.
The current in use commercial transformers are 600-1000 watt multitap boxes being switched on and off by X-10 appliance modules. New transformers will be significantly smaller in wattage.
  #115
Old February 3rd, 2011, 04:34 PM
Thomarann
Guest
Posts: n/a
Old thread but my contribution:
I am just setting up a new HT3Pro system and have the following:
1. all closet lights off after 10 minutes
2. main floor bathroom light off after 20 minutes Sat/Sun from 5am-8am (as our 7 year old who gets up to watch TV always leaves it on)
3. bathroom fans off after 20 minutes after light turned off (if fan is on when light turned off) or 20 minutes after fan turned on (if light is off when fan turned on) except for the main bathroom where we shower it is 30 minutes to clear the humidity
4. outside lights on 30 mins after sunset and off 30 mins before sunrise (we used to turn them off at 11 pm but after we were broken into we leave them on all night now)
5. decorations (trees/lighted snowmen/xmas lights, etc.) on at 6pm and off at 11pm
I am trying to make the HA useful and not intrusive to get the WAF so I read through this whole thread with interest and would like to get more ideas from others.
Marc
  #116
Old July 27th, 2011, 09:58 AM
simon templar simon templar is offline
Seer Plus
I see that a couple of people are talking about "When we are away..."
Did you guys connect your alarm system to homeseer, or is it just an EVENT that you called AWAY that will turn off most of the appliances ?
  #117
Old July 27th, 2011, 10:29 AM
nightwalker nightwalker is offline
I have an away mode that I set up with a series of HomeSeer events. All it really does is turn off everything not needed if no one is home as well as set the alarm. There's more to it of course but that's the basic Idea and everyones away mode is different based on their needs.
Marty
  #118
Old July 27th, 2011, 10:59 AM
Seer Plus
Hi ,
What interest me in what you wrote is "as well as set the alarm".
What kind of alarm do you have, and how good is it with homeseer ?
  #119
Old July 27th, 2011, 11:29 AM
Steve Q's Avatar
Like nightwalker, my "away" mode turns off everything not needed. This Homeseer event will execute automatically when both cars are gone, or can be executed via a button on an x10 remote. I have a separate button to "arm alarm" . If any door is opened when the system is armed, Homeseer will sound a loud alarm and announce "the police have been called". I use this Homeseer event for "armed at home" and "armed away".
Steve Q
  #120
Old July 27th, 2011, 11:30 AM
Seer Plus
How do you manage homeseer to know that the cars are gone ?
